Has anyone replaced the H7 high beam with LED
Old Aug 9, 2019 | 09:19 PM
MiniKar's Avatar
MiniKar
I'd like to have more light on the high beam in my R53. The Xenon is nice but I would like more white light.
Has anyone replaced the H7 bulb with an LED for the High Beam ?
I'd like to hear from you please.
Old Aug 13, 2019 | 08:37 PM
spyder152's Avatar
spyder152
I'm interested too, Not sure how the LED will work when day time lights are on, lights are not on full power.
Old Aug 16, 2019 | 09:12 PM
PHXDave's Avatar
PHXDave
MOD Mini did...
Looks like it works pretty well.
Old Aug 17, 2019 | 08:48 AM
CRC's Avatar
CRC
I would also like to replace the H7 bulb with something that gives more light, but I am concerned that a too powerful bulb will burn/discolor the reflective part of the headlight.
Any suggestions?
Old Aug 17, 2019 | 11:04 AM
lotter1's Avatar
lotter1
I replaced the highs with LED's. The highs are definitely brighter with the LED's. I think the ones that Mod mini used are no longer available or they were not when I bought mine. The install was simple. The DRL's do flicker for a couple of seconds when the car is first started.
Old Aug 18, 2019 | 10:03 AM
CRC's Avatar
CRC
Is there a brand/make of LED light that anyone can recommend?
Old Aug 20, 2019 | 11:00 AM
BMUN8IVE's Avatar
BMUN8IVE
Correct, those are no longer available.
Which did you go with?
Old Aug 20, 2019 | 12:09 PM
lotter1's Avatar
lotter1
I ended up buying from the zon, OEDRO H7 LED. Which it is showing now as unavailable.
Old Aug 21, 2019 | 08:24 AM
Soul Coughing's Avatar
Soul Coughing
I used these in my GP and they've worked well. You will get the flicker at initial start from the ECU checking for burnt bulbs, but it goes away quickly
https://www.amazon.com/gp/product/B07CBRXTT6/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07CBRXTT6/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Old Aug 22, 2019 | 07:46 AM
MVPeters's Avatar
MVPeters
Originally Posted by Soul Coughing
..... I used these in my GP and they've worked well ....
I've tried 3 different H7 LED bulbs in my 2002 halogen headlights.
They were all 'brighter', all 'whiter' (or blueish) & all had a lot more glare. None provided any improvement in real on-the-road terms.
I'm not concerned with DRLs or color.
All I want is more light where I can actually use it.
The newer Torchstar do seem to be the best bet, but what is your real-world on-the-road experience?
The flickering of LEDs at startup, I am told, is a general circuit check which can't be programmed off whereas the bulb check can. (I haven't tried!).
Old Aug 26, 2019 | 05:40 AM
Soul Coughing
There is some adjustment with the location of the 'filament' inside the housing which helped with setting up the light pattern. I put them in my low beam as well, and there is a defined cut-off similar to projector headlights on my '03. The light isn't as good as them, but was better than the OEM halogen bulb they replaced. It sounds like you are a discerning customer, so they may not suit you needs.
JimmyChooToo
Electrical
Jan 24, 2018 09:30 AM
sevin
Electrical
Aug 19, 2017 09:08 PM
Legates01
R60/R61 Stock Problems/Issues
Jun 12, 2017 11:51 AM
corcorand
Electrical
Mar 2, 2016 05:35 AM
dosomething
Electrical
Jan 3, 2013 01:19 PM
