Leveling the Mini for transmission fluid change?
Old Aug 5, 2019 | 07:07 PM
nomar116's Avatar
nomar116
OK, simple question here but... what is a good reference to make sure my MINI is level when setting the transmission fluid level?
I checked the fluid once on a lift and a second time in my garage. The difference in temperature was about 10* C and a big difference in fluid coming out. I'm wondering if I had the car completely level...?
I had it on the lift two days ago and set the transmission fluid at about 46* C (the higher end of the acceptable temperature range).
Today, I wanted to check it with the car cooler so I checked it around 36-39* C as measured by INPA. When I took off the drain plug the temp was around 32* C (ambient) and fluid immediately started coming out. Eventually, by the time the car reached around 39* C, I had removed about 28 oz's of additional transmission fluid before the stream came to a stop.
When I drove the car, it was pretty smooth except the 1-2 shift was pretty rough / had a significant flare. This is matched with a S2 solenoid error in the TCU, so possibly a real problem with the transmission.
Old Aug 7, 2019 | 03:43 PM
nomar116's Avatar
nomar116
I ended up rechecking the fluid level and adding a little extra. The result smoothed out the shifting dramatically and I felt comfortable selling the car. Its now on to its new owner!
Initially using the driver's side window sill as a level reference didn't work. I think the car was a bit tipped back and thus I was able to draw out a little more fluid.
Instead, I taped some rope from wheel center to wheel center and leveled that. Alternatively, I could just look at how level my garage was and adjust from there.
I'm surprised at what a difference less than one inch in the front end made. I drained nearly about a quart too much out with the front end being just .75-1" above level...
joluga123
Mar 5, 2020 08:24 AM
Smitha6
40
Aug 19, 2016 05:26 PM
Miles30
Dec 17, 2015 11:52 AM
Aug 25, 2015 09:33 AM
GKoutek
Feb 13, 2011 02:53 PM
