F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Overhead lights can't turn on
Old Aug 1, 2019 | 07:17 AM
Michael Hayes's Avatar
Michael Hayes
I have a 2018 Clubman S, and at some point I must have permanently turned off the overhead lights and the reading lights.
Does anyone know the procedure for turning them back on?
Thank you.
Old Aug 1, 2019 | 04:41 PM
2017All4's Avatar
2017All4
Super Moderator
Not sure if you're saying the overhead switches are not functioning properly. Toggle them if you haven't.
Old Aug 2, 2019 | 07:03 AM
Michael Hayes
Toggling does nothing with the overhead dome lights, or the reading lights on either side of the mirror area. And, yes, I have checked to see if the rotary light intensity switch, above the headlights switch, and out of view of the driver, is turned up. Interestingly, the footwell lights work.
Old Aug 2, 2019 | 07:37 AM
2017All4's Avatar
2017All4
Super Moderator
If the fuses are all good, and you've flipped and held the toggles, and you've spun the dimmer, and you've done a small animal sacrifice when the moon was full, then it's time to call or visit your dealer's service department. Please let us know the outcome.
Old Aug 2, 2019 | 08:06 AM
Michael Hayes
I will be monitoring the phases of the moon for the next opportunity.
There's a particularly stupid rabbit who insists on sitting in our driveway, who just might be enlisted for the purpose.
I'll do anything not to visit the dealer.
Old Aug 2, 2019 | 08:39 AM
2017All4's Avatar
2017All4
Super Moderator
I think killing a bunny might make it worse. Call your dealer.
Old Aug 2, 2019 | 02:34 PM
TVPostSound's Avatar
TVPostSound
Thank you.
If your visor mirror lights are also inoperative, then the fuse is the culprit.
Also if your auto headlights wont turn off, same fuse.
Old Aug 3, 2019 | 11:59 AM
Michael Hayes
TVPostSound & 2017ALL4:
You were both right, and it didn't require animal sacrifice. The rabbit is much relieved.
I went back to the glove compartment, emptied it, then pulled off the fuse box door and extracted the miniature fuse box map. I found the brown 5 fuse and extracted it, but dropped it.
It felling the air-conditioning duct below!!!! Off to the auto parts store and brought an assortment pack of fuses - still not knowing which fuse it might be. After the store clerks stopped laughing, I went home and put a small towel below the fuse panel to catch any more dropped fuses.
I inserted the missing brown 5 fuse and what happened? The lights came on. The gods smiled upon my Clubman and the rabbit wept with joy.
Old Aug 3, 2019 | 12:26 PM
TVPostSound
I was about to suggest hiring a code breaker to explain that stupid paper fuse diagram, but glad it worked out.
Old Aug 3, 2019 | 12:36 PM
2017All4's Avatar
2017All4
Super Moderator
Now we will all form a drum circle, chant, and seek an answer to the deeper cosmic question: Why did the fuse blow?
The rabbit doesn't care, but MINI owners far and wide are wondering...
Old Aug 3, 2019 | 01:30 PM
TVPostSound
My response was based on my experience.
A result of the hot wire to the driver vanity mirror light. The wire broke and shorted to the pivot inside the headliner.
It seems to get weak by turning the sunshade to the drivers window.
The sun is to my left going to work and returning home.
That sunshade gets at least 4 position movements per day.
Old Aug 3, 2019 | 04:34 PM
Michael Hayes
TVPost Sound:
How in the world did you figure this out?
I have the same daily drive with the sun on my left hand side each way, and yes, I use the visor.
Would taking down the visor and nipping off the wire solve this? I really don't need a lighted visor.
Old Aug 4, 2019 | 10:33 AM
TVPostSound
TVPost Sound:
I wouldn't recommend it!!
That was my issue. If you blow the fuse again, I would look into it.
You can check the wire.
Remove the cap, pinch the white clip to remove it, and slowly pull the visor down, and look at the wires.
Old Aug 4, 2019 | 04:11 PM
2017All4's Avatar
2017All4
Super Moderator
If the moon is full. Otherwise, take it to the dealer for warranty repair. Lighting fuses should not blow under normal use.
Old Aug 19, 2019 | 11:03 AM
2017All4's Avatar
2017All4
Super Moderator
So, Mr. Hayes, what was the final outcome???
Old Aug 19, 2019 | 11:26 AM
Michael Hayes
I'm not swinging the visor from side to side, just in case that really did cause a wiring fault, as was described above. A little voodoo for the ju-ju man, So far it's OK.
Old Aug 19, 2019 | 11:57 AM
2017All4's Avatar
2017All4
Super Moderator
The mystical self-healing powers of British-made cars, their wonders to behold.
Years ago I was gassing up our V12 XJS the evening prior to a planned road trip. After filling the tank, the Jag wouldn't start. I called my British mechanic, at home, on a Friday night. He was a few beers into his evening. He told me to hold my phone under the bonnet and crank the car, which I did, right there at the gas station. My mechanic, having heard whatever he heard over the phone, told me to wait 10 minutes, restart the car, drive it home, and park it in the garage to be towed into his shop on Monday because, he informed me, the car would only start one more time, just enough to get me home.
I waited 10 minutes, cranked the car. It started. I drove it home and parked it in the garage and we took another car on the trip. The next Monday, prior to calling for a tow, I tried to start the car. It would not start.
When I arrived with Jaggie in tow, my mechanic was waiting, with a small electrical part in hand. About 10 minutes and $80 later, the Jag was purring. I asked my mechanic how he knew what the problem was, to which he replied in the drollest of British accents, "Well, how do you know what you know?"
True story. And, to make it sweeter still, that old British mechanic, may he rest in peace, had a bit part as one of the MINI drivers in the original Italian Job movie. His XKE also appears in that film.
Don't fight the karmic flow.
Old Jan 6, 2024 | 04:01 AM
Neil_Ireland's Avatar
Neil_Ireland
Wrong thread, please ignore.
conger
Electrical
Mar 5, 2015 06:33 PM
Rogerinorlando
R57 :: Cabrio Talk (2009+)
Jul 9, 2014 08:37 AM
Gentlefury
Aug 20, 2011 06:44 PM
BoCRon
Sep 27, 2005 04:30 PM
