Fresh air/Recirc not working
Old Jul 31, 2019 | 06:32 PM
ZeroLav's Avatar
ZeroLav
2011 MCS Hardtop.
The AC and heat blend door works, and I can switch from cold to hot no problem. It seems, though, when I push the recirc button, nothing at all changes. No flapish noises, no change in air temp.
It's monsoon season here in Arizona, so the humidity is definitely noticeable. Our car is stuck on "fresh". Is there a way I can switch it to "recirc"? Even if it stays broken, I'd rather have it broken on recirc.
Thanks--
Old Jul 31, 2019 | 08:11 PM
MiniToBe's Avatar
MiniToBe
examine the flap. remove the battery cover and take a look at it.
Old Aug 2, 2019 | 12:20 PM
mkov608's Avatar
mkov608
Yes, get yourself a Foxwell NT520 or the NT530 scanner; if the switch is defective on the IHKA/IHKS control module, the scanner can move the position of the flap.
Contact Elly at Foxwell, and tell her Mark sent you. You'll get Forum Member pricing.
elly@foxwelltech.com
Old Aug 2, 2019 | 12:25 PM
ZeroLav's Avatar
ZeroLav
I'll shoot her an email. I dont think the switch is bad, as I can hear the tell-tale click-click-click of the door trying to move from the dash. I can hear it once or twice in our 45 minute commute each day. Once in a while I hear it flap open or flap closed, but it's been a while. Gotta just get in there and try to manually close it.
That scanner is way cheaper than I thought it would be, though...
pvtryan478
Oct 6, 2016 08:25 PM
hook3549
Mar 30, 2015 12:12 AM
Jolio
Factory JCW Talk (2009+)
Jun 25, 2011 05:39 AM
freezr
Jun 15, 2008 11:53 AM
1lesssuv
Oct 29, 2002 12:29 AM
