In need of help
Old Jul 30, 2019 | 07:19 PM
Zigcali's Avatar
Zigcali
In need of help
Have a 2012 r55 s. Parked my mini and the next morning would not start. The night before it ran weird and no turbo power. Stopped after a little bit and shut off the car and turned it back on and ran fine. Looked at the code on car and said low fuel pressure. After reading online sounded like it was the HPFP. Replaced that and fuel pump under the back seat. And nothing. Car will start and run for 5 or 10 seconds and die. I’ve tried so many time to see if it would prim. I’m at a lost. Help
Old Aug 1, 2019 | 06:04 AM
MiniToBe's Avatar
MiniToBe
can you check the live data and see what are the numbers you get on the high pressure fuel rail?
where are you located?
Old Aug 1, 2019 | 01:51 PM
Zigcali's Avatar
Zigcali
I have been able to test the pressure yet due to working and no equipment. Will check this weekend. I’m located in northern Colorado
Melly Fresh
Jan 9, 2018 11:48 AM
mdbsat
Sep 7, 2008 07:06 AM
Megan Racing
May 3, 2007 09:01 PM
kenchan
Midwest
Oct 4, 2003 06:58 AM
