Oil Leak - Advice
Old Jul 30, 2019 | 04:11 PM
Frixos's Avatar
Frixos
Oil Leak - Advice
I have an oil leak on my 09 R56 Justa. Could you all provide guidance? Why is it leaking? What needs to be done?
Old Jul 30, 2019 | 04:17 PM
mkov608's Avatar
mkov608
Your valve cover gasket has failed. It's simple to replace.
https://www.fcpeuro.com/products/min...co-11127567877
Or you can find other vendors.
Old Aug 3, 2019 | 08:07 AM
Frixos's Avatar
Frixos
How can I be sure it is only the gasket and not the valve cover itself?
Old Aug 3, 2019 | 08:49 AM
cooper48's Avatar
cooper48
Clean it, retorque the valve cover bolts and see what happens.
Old Aug 5, 2019 | 07:18 PM
Frixos's Avatar
Frixos
I replaced the gasket today. Everything was going great until I was putting the cover back on, and I managed to strip one of the bolts. So now I'm waiting for the new ones (bought 2, just in case another one bites the dust).
I took these four pictures with the cover off. Is there anything you all can see that I should be aware of or concerned about?
Old Aug 5, 2019 | 07:51 PM
mkov608's Avatar
mkov608
Oh my! That is very dirty! How many miles are you driving before oil changes? What type of oil and filter are you using?
Old Aug 5, 2019 | 07:54 PM
Frixos's Avatar
Frixos
I couldn't tell you how often before 80k miles, but until 100k miles it was done every 7.5k miles. After 100k, every 5k miles.
Currently at 122k miles.
I used Liqui Moly between 80-100. After that, Pennzoil Platinum High Mileage 5W-30 Full Synthetic.
Is there any way to clean this dirt off?? What would you recommend?
Old Aug 5, 2019 | 07:59 PM
mkov608's Avatar
mkov608
I have used SeaFoam Spray with great results; If I remember correctly, you can also use SeaFoam Liquid in your engine oil and it will emulsify all those carbon deposits. Follow the instructions on the label. I've never tried SeaFoam in my oil; since we are the original owners, and I've changed the oil every 7.5K miles.
What type of filter are you using?
Old Aug 5, 2019 | 08:31 PM
Frixos's Avatar
Frixos
Thank you for that recommendation!
This one:
Amazon Amazon
Old Aug 6, 2019 | 06:02 AM
Minidogger's Avatar
Minidogger
Don't use seafoam in the engine oil. It is not a lubricant. There are reports of ruined engines from this.
The coked oil buildup isn't really hurting anything. It is an old car. Keep changing the oil at 5K & it will run for a long time.
Old Sep 3, 2019 | 06:42 AM
That is a little dirty. My guess is the person before did the long services. Just keep changing the oil.
Lots of people like this stuff. And its liqui moly.
https://www.ecstuning.com/b-liqui_mo...00ml/lm2037kt/
On that end of the gasket you can take your time and clean off the cooked oil sludge and make sure it does not fall back into the engine.
quikdime
Jul 5, 2019 10:17 PM
vhsnap
Sep 3, 2017 04:24 PM
Cedros
Mar 21, 2017 01:50 PM
DRoc7822
Feb 15, 2016 12:47 PM
bigserb3
Feb 9, 2015 02:24 PM
