Water dripping through airbag cutout on C pillar
Old Jul 27, 2019 | 12:09 AM
craney's Avatar
craney
I just washed our 2008 Mini Cooper R56 (no sunroof) and when I was putting it back inside I saw some drips of water coming into the car from the airbag cutout on the passenger side C pillar.
I've done some searching but can't really find threads for non-sunroof leaks. Any ideas what would be causing it?
The car doesn't have any obvious rust damage and the external gutter rail looks OK. I found a thread for a different model Mini that said you take the headliner out to access the screws holding the gutter on.
My Haynes repair book has a procedure for taking the C pillar cover off -
  • disconnect battery
  • wait 5 mins
  • remove rear seat
  • remove lower seat belt bolt (and replace with new one)
  • carefully pry off trim cover near top of panel, remove the screw, then pry off the panel
  • installation is reverse
but that may not expose the source of the leak. The headlining removal procedure isn't included in the book.
LIVNLRG
Oct 20, 2011 04:53 PM
miniSQ
Jul 27, 2009 08:46 PM
bb100
Jul 24, 2008 02:39 PM
mox
11
Jun 7, 2008 03:28 PM
Red
26
Dec 10, 2005 06:42 AM
