R55 Creator c310+ adaptation reset
Old Jul 22, 2019 | 08:50 AM
Caleb S.'s Avatar
Caleb S.
Hey folks. I've recently done a lot of work to my 2008 Clubman including head gasket, used head, vvt solenoid replacements, timing chain, etc.
I purchased a Creator C310+ so that I could clear the DME Adaptations as I get a slight stumble at start up before the engine smooths out. This causes my check engine light to come on with misfire codes and intake timing over retarded codes.
The closest BMW dealership is over an hour away and one of the technicians suggested I try this tool.
The scan tool seems to be a great little tool (I now have three scanners), but the interface seems a little hard to navigate. I can't seem to find where the option to clear my DME Adaptations is.
Any help would be greatly appreciated.
Old Jul 22, 2019 | 09:16 AM
MrGrumpy's Avatar
MrGrumpy
With my scan tool (not the same one, so it will be different) it is in a sub-menu under maintenance I think. In the motor control electronics menu.
Honestly I had to spend a good while just going through menu after menu until I came across it. If a tech told you to use it, it should be in there somewhere you might have to dig for it under something else in the menu.
Just a suggestion, I haven’t used that scan tool.
And instead of adaptations, it may possibly be listed as “reset learned something or other”
good luck
Old Sep 17, 2020 | 10:04 PM
Stangr55's Avatar
Stangr55
Were you able to take care of the codes with clearing adaptations? I have a 2008 r55 with an identical situation.
if not did you find the problem. Stan.
Old Sep 17, 2020 | 10:20 PM
Stangr55's Avatar
Stangr55
08R55 adaptations
Were you able to clear the adaptations and did this solve the code problem. I have the identical situation. If not how did you fix it?.
speedman
Sep 25, 2019 04:59 PM
911***
May 31, 2016 08:13 AM
El_Duderino
Mar 17, 2016 01:25 PM
FEB07cooperS
Dec 8, 2011 04:49 PM
Nick_T.
Mar 7, 2005 09:33 AM
