R56 Innova scan tool?
Old May 28, 2016 | 01:51 PM
911***'s Avatar
911***
Innova scan tool?
I bought an Innova 3100i scan tool, but i can't seem to get all the codes to pop up on it. I have the Steering lock code on my dash, but I can't reset it with this scan tool. It is an OBD2 and is made for "all" makes and models….
Anyone else using one of these?
Old May 28, 2016 | 03:08 PM
ZippyNH's Avatar
ZippyNH
You cannot reset a code if the fault is still there...
Did you fix the fault, then try to clear it?
Maybe 90+% of the codes are reset able with a generic odb2 scanner.....I used a $20 Harbour Freight one that does most stuff (sale, and coupon, was maybe $35).
Some "hard" emissions codes need a pro tool, as do some unique "manufacturer" codes.
Old May 28, 2016 | 03:20 PM
ZippyNH's Avatar
ZippyNH
One question...
Is the key/button in the ON position....but not running?
Old May 31, 2016 | 08:13 AM
The schwaben tool has pulled those and find more specifics and test certain areas.
https://www.northamericanmotoring.co...d-q-and-a.html
. But it will not fix it, because the problem need fixed.
More info here.
https://www.northamericanmotoring.co...nctioning.html
NathanMckee
May 11, 2016 04:46 AM
MacGuruTX
May 4, 2016 09:00 PM
jetmechinnc
May 4, 2016 06:19 AM
911***
May 3, 2016 01:03 PM
911***
May 1, 2016 11:15 AM
