R58 Best short shifter and coil over
Old Jul 17, 2019 | 09:06 AM
Kenny Woo's Avatar
Kenny Woo
A great big hello again to everyone!
I would like to ask for some recommendations on a short shifter kit and coilover for my 2013 R58 Cooper S..
I feel the throw of the shifter now is quite long and deep and something shorter and more performance oriented would be great as I have track plans for the car. Some show a simple CNC stick whilst others show a multitude of parts. I was hoping for a good recommendation.
I plan to eventually take the car to track quite often so I would like a good trackworthy set of coil overs that hopefully is also comfortable enough to use on the roads. Some recommendations would be most most appreciated.
thank you very much
Old Jul 17, 2019 | 10:39 AM
vetsvette's Avatar
vetsvette
Moderator
For my R56 MCS I ended up installing the Cravenspeed adjustable short shifter, shift well kit, and the S4S Billy Club shift ****. That's what I have on my F56 now too. Only difference is I have the billet aluminum shift **** now rather than the Delrin version. Excellent combination IMO. The shift well and **** can be added later, but I would recommend the short shifter and retaining clip be installed at the same time.
https://www.cravenspeed.com/adjustab...r56-2007-2013/
https://www.cravenspeed.com/shifter-...-pro-for-mini/
https://www.cravenspeed.com/shift-we...r56-2007-2013/
https://www.sneed4speed.com/mini-cooper-shift-****/
Old Jul 17, 2019 | 11:07 AM
Altecfenix's Avatar
Altecfenix
I ran KW V1s for a while and loved them.
Old Jul 17, 2019 | 06:46 PM
Kenny Woo's Avatar
Kenny Woo
Thank you very much for the recommendations!
I will order in the short shifter later today!
The popular coilover choices seem to be between the Bilstein and KW... Which one gives better road comfort? If there is such a thing in coilovers.... Haha.. 😁
Old Aug 20, 2019 | 05:33 AM
Ohlins are my vote, but you could get KW, ST, and H&R are some good brands.
https://www.northamericanmotoring.co...on-my-gp2.html
Old Aug 20, 2019 | 08:45 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
For the short shifter I use the Cravenspeed in both my cars as it allows me to adjust it exactly how I like it not too short, but short enough to give a good feel.
https://www.waymotorworks.com/craven...r58-coupe.html
Then for coilovers we actually have our own custom KWs that have our own setup that ride firm but not harsh daily, and provide awesome track performance with the linear springs that provide you with the best feedback and predictability.
https://www.waymotorworks.com/kw-var...r55-56-57.html
But if you really do want to go to the track you're going to for sure need camber plates or you'll murder a set of tires.
https://www.waymotorworks.com/vorshl...lates-r58.html
While you have the rears out it is the ideal time to add a rear sway bar as it will be the biggest gain in handling.
https://www.waymotorworks.com/wmw-rear-sway-bar.html
Old Aug 21, 2019 | 05:35 PM
Kenny Woo's Avatar
Kenny Woo
Hi folks!
i have received my cravenspeed short shifter, the clips and the plastic gate cover. I also ordered the gear ****!
i haven’t installed it yet but I hope to in the next 2-3 weeks.
Am putting down the order for a KW V2 this end of the week too so I want to fit everything together when they all arrive! Thanks a lot for the suggestions!
price different between v2 and v3 for the kw was quite substantial. Seems V2 would be the best compromise.
Old Aug 21, 2019 | 09:08 PM
WayMotorWorks
Vendor
The V2 is ideal as it will be everything you need. And with our custom setup it's matched to the car. You really only need V3 if you are building a track car and have the knowledge to adjust it for your needs.
Old Aug 26, 2019 | 06:38 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Running the Cravenspeed adjustable and Ohlins here but you can't go wrong with V2's. Don't forget a slush fund for the RSB, Vorshlag camber plates and adjustable lower trailing arm links. Short of a full on race setup that will let you dial it in to a fair thee well. The R58 has a more forward weight bias than the R56 so start at the softest setting on the RSB. Then dial it in when you get some sticky shoes. Mostly though, have fun!
Splattj
Sep 10, 2015 08:20 AM
Rrotz
Jun 4, 2015 05:09 AM
r56Ter-Bow
Aug 1, 2014 04:17 PM
1304
Dec 11, 2013 06:23 AM
