Test time for my new friends: Interference engine - bent valves...blown pistons?
Old Jul 15, 2019 | 07:54 AM
idosubaru's Avatar
idosubaru
sorry if this should be included in my other post - to me this seemed like a different topic and could conflate the other...
If interference occurs do these:
a. bend valves
b. damage pistons
c. damage the block
d. all of the above are likely?
Old Jul 15, 2019 | 08:42 AM
Yupetc's Avatar
Yupetc
a. bend valves
b. damage pistons
c. damage the block
Most times just bent valves. If it's heavily modded while the internals are stock, then I can't say it won't damage the engine internals.
Old Jul 15, 2019 | 09:09 AM
idosubaru's Avatar
idosubaru
Great, thanks. I know nothing is guaranteed but it's all stock, non-turbo.
Old Jul 15, 2019 | 04:51 PM
MiniToBe's Avatar
MiniToBe
It depends on the cause!
It might interfere for many reasons and each one comes with its issues. For example, loose timing chain tenioner might cause bent valves. If the vacuum pump seizes, then you have more damage like bent valves, broken chain, and broken ex sprocket bolt, and some damage to the block....and so on.
Old Jul 16, 2019 | 06:13 AM
idosubaru's Avatar
idosubaru
Is the timing chain easier/less labor if the engine is out? It's a manual trans so I could pull the engine and do the clutch and timing chain (and possibly head work) at the same time if there's significant time savings.
Sure thing, I'll get the valve cover off and check, seems likely it's the chain tensioner and guides. The vacuum pump was replaced by the dealer 2 years ago and the noise/still turns over/'starts', etc seem to point to chain tensioner/guides.
Old Jul 16, 2019 | 06:29 AM
MiniToBe's Avatar
MiniToBe
I read your other post again. the noise you mentioned could be a loose/flown valve rocker follower on the intake side. I have heard a couple of stories about that. So, yeah you have to first remove the valve cover and check the followers too.
everything is easy once the engine is out, but you have to remember to do the final angle on the crankshaft bolt after installation unless you have someone holding the engine.
I have not done a clutch yet, but if I were to do it, I would either remove the sub frame and slide it from the bottom, or remove the nose and pull the whole thing out. My average speed now is about half a day to pull the nose and have the engine on the floor.
Old Jul 16, 2019 | 11:04 AM
idosubaru's Avatar
idosubaru
Great, thanks. I'll diagnose first and report back.
danraabe
Dec 15, 2017 12:04 PM
AirFox747
Apr 28, 2012 05:06 PM
Bgpacker
Apr 26, 2012 05:57 PM
RobRuz
11
Oct 21, 2011 01:07 PM
redman2002
May 12, 2010 05:02 PM
