2011 Mini Cooper s N18 engine is toast
Old Jul 9, 2019 | 10:14 PM
Knighgre's Avatar
Knighgre
Well my oil pump filter got clogged so my engine ran like 3 miles with out oil and fried my engine what would be a good option it’s a 2011 Mini Cooper s with the n18 I’m looking to just swap another engine into it and I was wondering if a 2012 n18 would work as a replacement.
Old Jul 10, 2019 | 05:38 AM
MiniToBe's Avatar
MiniToBe
oh man, sorry to hear that...personally, I always try to cheaper way which is rebuilding the engine if it still can be saved.
to your question, as long as it has the continental high pressure fuel pump, you should be fine. if you get the one fitted with Bosch HPFP, then you need the ECU for that engine and then you need to pair it with your car.
where you located?
Old Jul 10, 2019 | 11:09 AM
Knighgre's Avatar
Knighgre
I’m in the Portland Oregon area
Old Jul 16, 2019 | 09:59 PM
cargusjoh's Avatar
cargusjoh
2011 and 2012 to March 2012 manufacture date are identical Continental HPFP. April 2012 was the Bosch. If you are on the boarder please find a way to verify by hand. I don't now how to know the difference.
Old Jul 22, 2019 | 11:40 AM
Check the production date on your door then match to what we have here, or check the VIN on that engine if its 8/2010 - 3/2012 you should be fine.
: https://www.ecstuning.com/News/MINI_...el_Pump_22527/
mountainhorse
Mar 23, 2025 06:55 PM
Knighgre
May 21, 2019 08:31 PM
HaveATank
Nov 19, 2015 07:40 PM
Batmobox
Jul 4, 2013 10:22 AM
Calvin77
30
May 9, 2003 02:21 PM
