07 mcs died, possible dme failure?
Old Jun 28, 2019 | 12:45 PM
2007astromini's Avatar
2007astromini
my 07 mcs died after cel came on and code read as bad knock sensor, I had to order one. on the way home, my car died and would not restart. replaced knock sensor and my mcs will still not start. scanned the codes again, and it has the code for lo and high reading on cam position sensor(CPS). as well high and low fault for co2 sensors. I replaced the cps with oem component and will still not start, read the codes again. it has the same codes as before. But also has a dme fault.
Old Jun 28, 2019 | 01:27 PM
MiniToBe's Avatar
MiniToBe
check the wires to the DME and relays next to it. also, do a quick compression test just to verify mechanical correctness.
2009MinicooperSclubmen
Nov 19, 2019 06:15 PM
Oz2814
Jun 14, 2019 08:43 AM
boostedmax
May 21, 2019 12:23 PM
RCBound
May 7, 2018 06:03 AM
MINIjunky
27
Mar 31, 2004 05:56 PM
