Left rear turn signal is stuck on
Old Jun 18, 2019 | 05:15 PM
Mike Jacob's Avatar
Mike Jacob
2003 Mini Cooper S
My left rear turn signal is stuck on (orange one). It does not flash - just a steady light. It stays on with everything off.. even with the keys out of the ignition. I tried switching bulbs and it’s the same story. It turns off when I use the right turn signal. Any use of that light gets it stuck on. I’m clueless.
Also, I’ve just noticed water with my battery. Then today, behind the passenger door well. Maybe that’s related.
Any ideas are greatly appreciated!
Old Jun 18, 2019 | 05:28 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Originally Posted by Mike Jacob
2003 Mini Cooper S
Most likely you have sun roof. Do a search on leaking sunroof and general body module that is by the right wall of the passenger (north amerikan) side foot well. Water intrusion that damaged electronic is the likely cause.
Old Jun 18, 2019 | 05:39 PM
Mike Jacob's Avatar
Mike Jacob
I had that problem a couple months ago. I fixed the leak. Would it be causing problems now?
Old Jun 18, 2019 | 05:41 PM
pnwR53S's Avatar
pnwR53S
You bet! With a bit of care most can fix it if rectified early. Make sure you disconnect the battery before attempting to remote the BCM as well as reconnecting it.
Old Jun 18, 2019 | 05:49 PM
Mike Jacob's Avatar
Mike Jacob
Can you link me to what I need to do, please. I’m very new to this. And if you have any additional information about my other leaks. Thank you so much
Old Jun 19, 2019 | 02:37 PM
BCM here: https://www.northamericanmotoring.co...-used-bcm.html
Sunroof drain here: https://www.northamericanmotoring.co...of-drains.html
Old Jun 19, 2019 | 02:42 PM
Alpha Motoring's Avatar
Alpha Motoring
More than likely your BCM got corroded due to the previous sunroof leak.
ushankaurmom
Jun 18, 2019 02:52 PM
ushankaurmom
Jun 18, 2019 08:16 AM
gob15
Oct 14, 2018 02:30 AM
PW Clubman
Sep 22, 2012 05:36 PM
PW Clubman
Sep 22, 2012 05:33 PM
