R56 Yellow brake and traction control always on
Idk what happened, I was driving one day and the yellow brake light and traction control light on my dash popped up and doesn't go away.. and my button to turn traction control off dosent work any more.... Anyone have any experience or ideas about this?
Most often times, it's because a speed sensor (aka ABS sensor) on one of the wheels has gone out. You can get a good scanner to find out through the OBDII port to see which one it is then go from there. Speed sensors are quite cheap, about 30-50 bucks each.
If the speed sensors checked out, then very likely you'll be dealing with the ABS or Traction Control Module, these will be quite costly to repair. Parts cost are in the high hundreds and labor will cost more,too.
ladzio
Sep 14, 2019 11:43 AM
racemd
Jul 16, 2018 08:43 AM
k_h_d
Tires, Wheels, & Brakes
Aug 9, 2013 01:50 PM
