I have an 05 JCW but the engine was swapped with an 06 S. Looks like they kept all the important stuff but I'm not positive about the supercharger. I found the dimesions of like 2.2 and 2.58 or something but I didn't see mention of where that measure was coming from. Is that at the rib or at the front lip?
F.Y.I. I believe the stock JCW SC pulley is an 11% overdrive (someone correct me if I'm wrong) so moving to a 15% will get you where you want to go.
Yes....the stock JCW supercharger pulley is around 11%........I had all the diameter measurements written down here somewhere.....but I can't find them right now....
To the OP....if you are going to remove your supercharger pulley, it will take a different puller depending on if your pulley is a JCW version or just an S version....so you will need to determine which one you actually have.....I have a factory JCW and a factory S if you want me to try and measure the pulleys for you
I was only getting 12-12.5 lb of boost. To make sure everything is how I want I ordered the 15% pulley, 2% crank, DT BPV and a few other maintenance items. should run a little better then.
