Emissions readiness "components" incomplete
Old May 17, 2019 | 06:02 PM
humming's Avatar
humming
Hello all, I had a p1498 code about a month ago, decided to reset the ECU via the torque cell phone app for Android. It's been weeks now and the last one won't flash to ready. Sometimes the EML light turns on while driving, but there is no code or pending codes.
Any ideas?
Old May 17, 2019 | 06:18 PM
humming's Avatar
humming
Well, the p1498 code just popped up again after my last drive, so back to hunting for leaks.
Old May 18, 2019 | 07:31 AM
cristo's Avatar
cristo
Alliance Member
Too bad the reader doesn’t elaborate which components are incomplete.
Old May 20, 2019 | 06:17 AM
ItsmeWayne's Avatar
ItsmeWayne
The readiness will take usually around sixty miles to go off. This is so you can not beat emissions testing with a quick reset. It is a pain in the ***, but it is how they are set up (in all newer OBD2 cars)
If it keeps coming on, then there is still a problem with something, but each time, to get all the codes in readiness, will take some driving time.
I hope you can get the issue dxed and on the road again.
Old Apr 25, 2020 | 02:11 AM
minniedryver's Avatar
minniedryver
Torque monitoring app ?
Can anyone confirm that the "Not avail" monitoring flags shown in the torque screenshot below, appear correctly, and should not show any other values? My 2005 MCS failed state inspection the other day (likely due to lack of proper drive cycles since doing some repairs with battery disconnected). I did some driving immediately after the 'failure" at the inspection station and connected to torque once I got home from the drive.
My car shows the same "Not avail" flags as shown below but has all others showing "Complete" so I'm hoping I will now pass the re-test.
Thanks in advance!
Any ideas?
hidperf
Mar 29, 2016 05:20 AM
rckrzy1
Jun 11, 2014 11:12 AM
CycleHead
May 18, 2010 09:47 AM
Zag
16
May 28, 2009 01:30 PM
barnhillld
Jul 26, 2008 11:01 AM
