2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Is there a tire jack?
Old May 15, 2019 | 04:31 PM
creep's Avatar
creep
Does the F60 include a tire jack if you don't get the spare option? Previously with the R60 it included a tire jack.
Old May 15, 2019 | 05:51 PM
MrFunk's Avatar
MrFunk
No I don't think I've seen one in ours...
Old May 16, 2019 | 03:48 AM
F56-JCDub's Avatar
F56-JCDub
No, it is not included unless you get the spare package/option.
Old May 17, 2019 | 07:36 PM
gbilton's Avatar
gbilton
NO , if you don't already have a spare Out Motoring and Detroit Tuned sell spare kits which include everything you need
Old May 19, 2019 | 07:13 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
We have a full kit for the F60: https://www.detroittuned.com/mini-co...pare-tire-kit/
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old May 21, 2019 | 11:10 AM
18cmjcw's Avatar
18cmjcw
Originally Posted by Detroit Tuned
@ Detroit Tuned
I understand that there is a difference in the kit for F60s built post 11/17. I think the difference is a change in the jack and jack adjustment wrench. Is your kit for pre-11/17 cars. post-11/17, or do you have both variations available?
-Bob
Old Jun 23, 2023 | 03:20 PM
kerwooddr's Avatar
kerwooddr
Veteran: Navy
Got rid of the noisy and harsh Pirelli run-flat tires, replaced those with Continental Extreme Contact 225/50 R18. Added the BMW Mobility Kit in the off chance of a minor puncture. Wasn't satisfied with that, so I bought the spare tire kit (full kit, with jack and tools) from Detroit Tuned. Installed same, totally satisfied with this addition to the Mighty Mini:
Fits like a glove. Compartment liners by Canvasback, another worthy addition.
Old Jun 26, 2023 | 05:07 PM
ApexF60SE's Avatar
ApexF60SE
Hi Detroit Tuned... does this kit fit into the boot space of a F50 SE? I'm assuming the traction battery takes some of the space, maybe not.
Old Aug 22, 2023 | 02:03 PM
marker2037's Avatar
marker2037
Forgive my ignorance, but since I don't have a spare or jack, I am also considering adding this kit. Is there then a flat, hard cover made that sits over the spare tire kit or is it simply exposed as is and is visible once the tailgate is opened?
Old Aug 22, 2023 | 03:38 PM
Mini-Titan's Avatar
Mini-Titan
There is a cover on mine. My "Flat kit" is one I put together myself, but, I don't use a spare donut. I use an OEM wheel/tire that I put on TOP of the cover, and lash it to one side face-down, so that I can put things in the wheel cavity. Then, I have a plastic milk crate on the other side which wedges the OEM wheel/tire in snugly. I have a JCW, and all the "spare wheel/tire combo's" I've seen will not fit on the front. Plus, with AWD, I don't want an odd-sized wheel/tire anywhere...that would not play nice with the AWD system.
Old Aug 22, 2023 | 05:08 PM
kerwooddr's Avatar
kerwooddr
Veteran: Navy
The existing flat floor of the rear compartment fits fine over the Detroit Tuned spare tire kit. You can see the OEM cover propped up over the spare tire in the photo I posted earlier. With the OEM cover in its normal closed position, you'd never know there was a spare tire in the storage space below the OEM cover.
Old Aug 22, 2023 | 05:28 PM
marker2037's Avatar
marker2037
Hmm, I can’t visualize it. Are you saying the bottom floor cover of the empty rear compartment will simply sit on top of the Detroit kit? Would you have a picture of that?
Old Aug 22, 2023 | 05:58 PM
kerwooddr's Avatar
kerwooddr
Veteran: Navy
That is it, exactly as described:
Rear compartment, cover closed with spare tire kit underneath. Easy peasy.
Old Aug 22, 2023 | 06:02 PM
marker2037's Avatar
marker2037
Terrific, thanks. I suppose I was getting confused by your plaid liners in the pic, but they are just lining. Now I get it.
Old Aug 22, 2023 | 06:16 PM
kerwooddr's Avatar
kerwooddr
Veteran: Navy
These are liners made for the Countryman by Canvasback. Excellent product, well made, snug fit, highly recommended. I describe the package in detail with pics elsewhere in the forum, here:
https://www.northamericanmotoring.co...ountryman.html
Old Aug 23, 2023 | 06:27 AM
marker2037's Avatar
marker2037
So I actually think my car is missing the trunk cargo cover. If you look at my pic here, I only have the bottom floor covering.
if I look at this parts diagram, I see there is another flat cover that goes on top of the lower cargo area, shown in green. It appears my car doesn’t have this part.
Old Aug 23, 2023 | 06:54 AM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
@marker2037 Are you looking for confirmation that you're missing that part? Confirmed :-)
Old Aug 23, 2023 | 07:25 AM
marker2037's Avatar
marker2037
Pretty much haha . That’s what I figured.
Old Aug 23, 2023 | 12:23 PM
https://www.realoem.com/bmw/enUS/sho...33#51477380665
Yep its not there, and don't see a picnic bench either.
https://www.ecstuning.com/b-genuine-...h/51477433402/
Old Aug 23, 2023 | 01:03 PM
marker2037's Avatar
marker2037
Whoa, whoa, you guys are having picnics out of your Countrymans?!?
Old Aug 23, 2023 | 01:23 PM
kerwooddr's Avatar
kerwooddr
Veteran: Navy
Who doesn't? Hence the name, doncha know:
Picnicking with the MINI Countryman
Old Aug 23, 2023 | 01:26 PM
marker2037's Avatar
marker2037
Haha nice! I think I'll skip the picnic bench for now, but I definitely want the luggage cover.
Old Aug 28, 2023 | 08:02 AM
eric.stewart
I have the picnic bench option on my F60. It's been well used!
Old Aug 28, 2023 | 08:04 AM
Saves that back end from scratches also if you loading and hauling stuff.
Old Sep 24, 2023 | 06:48 PM
marker2037's Avatar
marker2037
I retrofitted the floor cover fyi. I only had to remove the brackets and it just sits there without locking into any hooks, but I’m cool with that. I could theoretically get the part that goes in the divider to accept the hooks and cut the carpet, but I don’t think the added expense is necessary.
michaelo
Aug 20, 2019 08:19 PM
Mrdi
Aug 7, 2015 01:06 PM
silence2-38554
Mar 30, 2015 08:14 AM
Kiyofox
Jul 8, 2014 10:06 AM
oog
Jun 20, 2011 12:39 PM
