2011 Mini Cooper s n18 won’t start after engine failure
Old May 11, 2019 | 03:06 PM
Knighgre's Avatar
Knighgre
It’s a 2011 R56 n18 with 82,000 miles.
I was driving on the free way and Starter loosing power and rpms engine was still running, if I gave it to much gas it would make a rattling noise. I pulled off the free way after 2 miles and the car died and wouldn’t start so I was like dang my timing chain went out so I got the car back home and tried starting it. The car turns over but won’t start. So I pulled the valve cover off to inspect the timing chain and it looks completely fine all the guides are completely fine and there is no slack in the chain. There are no engine codes So I am stumped on what the issue is. Any ideas would be awesome
Old May 14, 2019 | 06:14 PM
mkov608's Avatar
mkov608
Check your fuel pressure, and make sure there is gas in the tank.
Old May 15, 2019 | 07:14 AM
S-2013's Avatar
S-2013
Any follow-up to this?
Old May 21, 2019 | 10:41 AM
Knighgre's Avatar
Knighgre
Full tank
It had a full tank of gas when it happened and no prior symptoms of fuel pump failure.
Old May 21, 2019 | 10:58 AM
MiniToBe's Avatar
MiniToBe
scan the car even if the CEL is not on.
Old May 21, 2019 | 11:14 AM
Knighgre's Avatar
Knighgre
No codes
Do I need a more expensive code reader because when I scan it there are no codes and it says I have no stored engine codes.
Old May 21, 2019 | 11:18 AM
MiniToBe's Avatar
MiniToBe
not expensive, but at least BMW/MINI specific. do you have sunroof?
Old May 21, 2019 | 11:20 AM
Knighgre's Avatar
Knighgre
No sunroof
Ok am probably going to take it place who can scan it with a bmw reader and I don’t have a sun roof
Old May 21, 2019 | 11:41 AM
MiniToBe's Avatar
MiniToBe
back in the day, my Countryman did something close to that and it was the fuel rail pressure sensor. Could you try and spry quick start/starter fluid to see if it is fuel related? Also, there is a green wire (ground) located on the valve cover in the back, check if it is tight? lastly, open the fuse box next to the ecu and swap the relays, specially the bottom one.
Old May 21, 2019 | 08:31 PM
Knighgre's Avatar
Knighgre
It’s tight I put in new relays and I tried the starter fluid thing.
tntaussie
Mar 15, 2022 03:23 PM
CmdZ
May 5, 2018 06:11 AM
minibeer
Jul 19, 2014 09:52 AM
BETOGTI
Jan 28, 2012 06:17 AM
Mboykin
Feb 28, 2010 07:53 AM
