Three honks on Startup.
Old May 6, 2019 | 05:34 PM
Brian715's Avatar
Brian715
I just got my mini, a 2008 s, and I love it so far. Has 119,000, miles. No engine lights or other warning lights on. So as the title says, I get into my car, put the key in the slot, push in the clutch and push the start button and the horn will honk 3 times very quickly. Everything seems to work fine otherwise, just a little annoying to my neighbors at 4 am when I leave for work. Any thoughts? TIA. I can take a video and put it on YouTube if that would help.
Old Sep 28, 2019 | 06:14 AM
Brian715's Avatar
Brian715
I think I may have found some info on this finally. I think my car has a dealer installed car alarm that makes it do this. I will post again when I finish figuring it out.
Old Sep 28, 2019 | 02:05 PM
A383Wing's Avatar
A383Wing
it should not do that at all...is it a factory alarm system? If so, something is wrong with it....might need to be taken to dealer to be diagnosed or re-programmed
Bryan
Old Sep 29, 2019 | 04:00 PM
Brian715's Avatar
Brian715
It's a dealer installed alarm. I got it used but after a little bit of forum searching, I found this has happened to a few people with Toyotas and also with dodges. It's called a Karr alarm system and when the valet switch isn't plugged in all the way it will honk three quick times before ever start. Looking at removing the alarm as I don't have any remotes or anything for it anyway.
Old Sep 30, 2019 | 01:32 PM
A383Wing's Avatar
A383Wing
Yes, probably a good idea to yank it all out of there
Bryan
Braldee
Nov 13, 2014 02:02 PM
dollbaby4559
Mar 23, 2012 08:28 AM
ammodave
Mar 6, 2010 09:23 PM
BearX220
Dec 31, 2006 10:51 PM
HowardPM
Jul 18, 2005 07:44 AM
