Navigation & Audio Valve Cover oil leak!
Old Apr 14, 2019 | 05:04 PM
jjcsnlynn's Avatar
jjcsnlynn
Just put the head on 500 miles ago but 200 miles ago I started getting an oil leak down by the down pipe.
I thought my turbo oil line was leaking, so after 3 hours of pulling it all apart, it is dry. I have oil on the oil filter housing and oil cooler but I changed gaskets to both of them when I put the head on 500 miles ago.
My mechanic son came over and says its the valve cover. I put on a new gasket on the valve cover when I put it back together. I did put some rtv in the two corners bt the fuel pump and vacuum pump. I checked the bolts and some are looser than when I installed it.
Is there anything that I should do other than tighten the bolts?
Gabe3
Feb 25, 2019 01:24 PM
Precious_Roy
Sep 12, 2017 06:55 PM
Standman
Nov 5, 2015 07:44 AM
JTmini08
Mar 8, 2014 03:20 PM
madmaxxed
May 22, 2011 06:33 AM
