Dash lights going crazy
Old Apr 14, 2019 | 09:52 AM
Paul Cleven's Avatar
Paul Cleven
I'm experiencing crazy dash lights and gauges when I shut the car off. 02 r53
All seems normal while car is running.
I've done the ecu software reset. Disconnected the battery for30 min. Still a problem
Ecu, ignition switch, stuck relay?
Help..... Ugh
Paul
Old Apr 14, 2019 | 06:23 PM
AZdsrt's Avatar
AZdsrt
How old is the battery?
Old Apr 15, 2019 | 02:02 AM
Paul Cleven
Dash lights
About 1 month
Tnx
Old Apr 15, 2019 | 08:24 AM
Check for water in the footwell near the BCM.
https://www.northamericanmotoring.co...working-2.html
https://www.northamericanmotoring.co...le-issues.html
Check for water in the trunk/boot also:
https://www.northamericanmotoring.co...ing-water.html
Old Apr 15, 2019 | 08:34 AM
Paul Cleven
Dash lights
Tnx!!!
Drivers side is wet. Pass side is dry.
I take it back is on pass side, yes?
Going to open up both sides when I get home from work, dry out, find leaks and clean up connections.
Old Apr 15, 2019 | 08:37 AM
Welcome. yep check that side thats wet out and make sure its not soaked and dry things out.
If you have a sunroof its those drain tubes most of the time.
https://www.northamericanmotoring.co...of-drains.html
Old Apr 15, 2019 | 08:55 AM
Paul Cleven
Yes to sunroof. Thanks for your help. I see in some other posts mention of a 40 pin connector. Is this behind the fuse block. Cant see yet with kick panel in place
Old Apr 15, 2019 | 09:04 AM
Yep, fusebox one side driver, BCM passenger side if i remember right.
thebluecanary
15
Oct 7, 2005 12:14 PM
spillman
May 21, 2005 09:20 AM
quinn
Detailing 101
May 21, 2003 09:00 AM
