Need advice/suggestions
Old Apr 9, 2019 | 06:17 PM
Brownguy01's Avatar
Brownguy01
So I’m driving home today and I hear a big clunk under my engine bay and come to find out my idol or pulley just disintegrated out of my car. I’ll be replacing the idler pulley later this week along with a new belt/ tensioner.
Should I replace anything else while I am working in that area? Is there anything special I need to know when replacing the idler pulley? I seriously have no idea how it just vanished out of the car unless it was made of some cheap plastic Thanks a lot
2003 R53
Old Apr 9, 2019 | 08:35 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Wow that is pretty epic.
Check to make sure there is no damage to the crank pulley.
we keep them all in stock
https://www.waymotorworks.com/idler-...-cooper-s.html
Old Apr 10, 2019 | 02:45 AM
Brownguy01's Avatar
Brownguy01
I checked it, felt tight. Thanks!
Old Apr 10, 2019 | 05:56 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Make sure you thread it into the correct hole (with recess) at lower-right of timing cover.
Some have mistakenly threaded it into the bottom hole in the corner which may, or may not have a bolt in it, which will result in a belt that's too tight and can't be fitted over the pulleys.
See THIS recent thread.
Old Apr 10, 2019 | 06:41 PM
WayMotorWorks
Vendor
I was more thinking of damage to the belt grooves so it doesn't damage a new belt.
zdw2082
Oct 5, 2015 09:59 AM
Jerry11357
21
Apr 11, 2012 08:02 PM
IQRaceworks
Tires, Wheels, & Brakes
Jan 19, 2012 02:09 PM
Ntobis
Apr 11, 2011 09:17 AM
Moxie D
Jan 14, 2011 02:10 PM
