R50/53 Yellow high beams
Old Mar 25, 2019 | 04:33 PM
Gurdy's Avatar
Gurdy
Yellow high beams
2005 hatchback has annoying yellow high beams.Looking to change the bulbs to white light. I believe the bulbs are H9 type. Any suggestions?
Old Mar 25, 2019 | 04:52 PM
BlwnAway's Avatar
BlwnAway
They should be H7's,
There are these:
Amazon Amazon
Or look at the Silver Star, if you want to stick with halogen.
Old Mar 26, 2019 | 03:43 PM
veedubpat's Avatar
veedubpat
There are these:
https://www.amazon.com/White-Halogen...39145650&psc=1
I wouldn't run a 100w anything in OE housings with OE wiring. Or anything over the factory 55w without relayed harnesses at the very least.
Right now GE makes the brightest H7 that is safe to use in OE-replacement applications:
Amazon Amazon
Old Mar 26, 2019 | 04:38 PM
BlwnAway's Avatar
BlwnAway
Right now GE makes the brightest H7 that is safe to use in OE-replacement applications: https://www.amazon.com/dp/B00GZHC2EE/?tag=2402507-20
I wouldn't either, in a halogen, but those are 100w comparable LED's, so nowhere near the heat as a 100w incandescent.
But honestly, that was just the first LED replacement that came up on search.
Old Mar 26, 2019 | 06:52 PM
MVPeters's Avatar
MVPeters
If you want to see where you're going, put in GE, Sylvania or Philips H7 bulbs.
Philips will last the longest.
If you don't want to see where you're going & do want to blind everybody else, put in the LEDs.
Old Mar 26, 2019 | 07:13 PM
BlwnAway's Avatar
BlwnAway
It would be nice to hear from others on this...
I've got some 75w equivalent LED's and I think they work as well or better than the SilverStar's I used to have. But maybe it's just me...
(I can't for the life of me remember where I got them)
And blinding others really shouldn't come into play here, so I don't worry about that.
Old Mar 26, 2019 | 07:19 PM
veedubpat's Avatar
veedubpat
That kit contained a pair of 100w halogen bulbs as well as a pair of LED bulbs; for low beam and high beam use.
Makes sense on how it was carefully selected now! :laugh:
StarlightBlueOxford
Jul 19, 2019 04:36 AM
ManikMini21
Electrical
20
Feb 21, 2016 08:16 PM
makzu
Feb 3, 2011 10:12 PM
bee1000n
Jan 11, 2010 02:42 PM
