Drivetrain Downpipes (Overboost?)
Old Mar 25, 2019 | 05:01 AM
Floydian's Avatar
Floydian
This is going to be a long thread so bear with me.
I have a 2015 BMW 120i F20 LCI with the N13 engine. (Turbo is Garrett MGT1549 ZDL)
It already has a K&N Drop in Filter, 70mm Cat-back exhaust, GFB DV+, Wagner Competition Intercooler, Racechip Ultimate, and NGK 5992 plugs from the Mini JCW, I run it on 99 Ron fuel.
I am planning on replacing the downpipe with a catless version, has anyone faced with boost spike or boost creep after fitting a catless downpipe on a piggyback tune such as Racechip? Unfortunately remapping the car is out of the question for me at the moment.
I posted here as the N13 engine is very similar to the N18.
Old Mar 26, 2019 | 11:35 AM
PEneoark's Avatar
PEneoark
Have you tried a BMW forum?
Old Mar 26, 2019 | 11:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I thought the boost control improved when I replaced the down pipe with a cat-less version. With less back pressure, seems easier for the waste gate to control the boost pressure.
Old Mar 26, 2019 | 02:28 PM
knt's Avatar
knt
Won't running a catless downpipe give you a dashboard error without a proper remap?
Old Mar 27, 2019 | 03:31 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
yes
Old Mar 29, 2019 | 06:25 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
You should have no issues with boost spike going catless. It's common on Subaru's but BMW's control method is different. The racechip is the wildcard. Normally with the stock tune you lose a little bottom end but pick it up on top. With a proper tune its power across the board.
Old Apr 4, 2019 | 04:06 AM
Floydian's Avatar
Floydian
No. Information on the N13/N18 is far more extensive here.
Yes it will, thats why I am planning to cancel any error codes from the downstream 02 sensor.
Thanks!
Old Apr 4, 2019 | 04:08 AM
Floydian's Avatar
Floydian
Does anybody know if the downstream narrowband O2 sensor effect AFR and fuel trims on the N18 engine?
Old Apr 4, 2019 | 06:34 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
It does not. It's sole reason for existing is to monitor the cat efficiency.
inimmini
May 7, 2012 09:42 AM
thestiguy
Apr 8, 2007 06:39 AM
autoxguy305
Dec 14, 2006 08:49 AM
MarioKart
Nov 27, 2006 10:17 AM
DarkMiniCooperS
Sep 16, 2005 11:33 AM
