JCW OBD Adapter which one?
Old Mar 11, 2019 | 05:42 AM
MikeMJCW's Avatar
MikeMJCW
I downloaded Bimmercode app to my Samsung Galaxy S8 and it's asking for a OBD Adapter in the Bluetooth settings. Where/which one am I supposed to get?
I tried posting this in the Bimmerapp thread but it wouldn't allow me to. I'm just trying to disable the ASD.
Old Mar 11, 2019 | 07:15 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Amazon.
Just search for bluetooth OBD and you will get more than you can imagine. Ipone works best with the WiFi ones, Android, bluetooth
Old Mar 11, 2019 | 07:28 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I use an Icar version, however Bimmercode changed the recommendation last year. Look on the website for Bimmercode as they have a list of supported devices.
Old Mar 11, 2019 | 08:35 AM
jmb2232's Avatar
jmb2232
When I first purchased Bimmercode, I used the Vgate iCar over a WiFi connection. Once Bimmercode started supporting bluetooth, I started using the OBDLink that I owned already. I like the bluetooth link better because it seems to be more stable. I have an android phone, btw. Hope this helps.
MikeB.
Old Mar 11, 2019 | 04:50 PM
N0B0DY's Avatar
N0B0DY
I also have a Samsung Galaxy S8 and I use the Veepeak bluetooth adapter. Just be careful of the fake ones being sold on Amazon..
Old Mar 11, 2019 | 07:57 PM
MikeMJCW's Avatar
MikeMJCW
Thanks folks, I just ordered the ASD defeat harness from Technic instead, that's the only thing I was looking to disable.
Old Mar 23, 2019 | 01:26 PM
MikeMJCW's Avatar
MikeMJCW
Help!!!! I got Vgate iCar Pro Bluetooth 4.0 adapter- inserted it- all looked good- then deactivated ASD- then unplugged it- and ASD never got deactivated. What am I missing?
I sent the ASD defeat harness back as it looked like to much work to install.
Old Mar 23, 2019 | 05:18 PM
jmb2232's Avatar
jmb2232
It's been a while since I reprogrammed anything but I recall there is a step like "save programming" or something similar that you have to do. The reason why I remember that is because I missed it the first time.
MikeB
Old Mar 23, 2019 | 06:22 PM
Mini_Vinnie
Moderator
did you hit code? Not being a jerk but you could have missed it.
After I code, I always disconnect from the app then close the app
Old Mar 23, 2019 | 07:20 PM
MikeMJCW's Avatar
MikeMJCW
Yes, but it asked me to purchase the full version, I thought this was a freebie. Why would I think anything is free? Well I guess it's $75 to turn off the ASD then.
Thanks Vinny, back home you would've gave me "ah scuppettada ngabba"
Old Mar 24, 2019 | 06:04 AM
Mini_Vinnie
Moderator
HA! nothing in this world is free
Thankfully, you will never have to buy it again for all the updates. Glad it worked out buddy
Old Mar 24, 2019 | 11:25 AM
MikeMJCW's Avatar
MikeMJCW
I like it better with the ASD off, car is so much more enjoyable.
IMO this feature should be on controllable thru the CID display console. As for noise cancelling it's possible Mini intended that but my guess would be that it's just a by product.
Old Mar 26, 2019 | 02:57 PM
MikeMJCW's Avatar
MikeMJCW
Is it a coincidence that my check engine light comes on 2 days after using the bimmercodeapp? Maybe it's because this is what I feared and why I was originally going to get the ASD bypass harness.
Old Mar 26, 2019 | 07:01 PM
Mini_Vinnie
Moderator
If you just shut the ASD off that shouldn't be the reason for a CEL. Pull the code, we can't help without knowing what code tripped it. Go to an Autozone type store and get it pulled for free
Old Mar 27, 2019 | 04:18 AM
MikeMJCW's Avatar
MikeMJCW
I have an app at the dealer. Code's- WTF happened to 4 Barrel Holley Carb's?
Old Mar 27, 2019 | 08:25 AM
elsnaibs's Avatar
elsnaibs
You are so right. I have a loaner while I have some maintenance plan stuff done, and the ASD in the loaner is SO NOTICEABLE OMG. I can't stand it.
entropy1
Aug 11, 2018 09:32 PM
BucksCountyR57
Oct 7, 2015 12:14 PM
cerenkov
Jul 13, 2014 03:13 PM
bk_mini
Aug 24, 2011 04:36 PM
Ohmen
Detailing 101
11
Jan 7, 2010 06:54 AM
