R50/53 Timing chain guides
On an R53 they are pretty easy.
Remove the timing chain tensioner
Support engine, remove pass engine mount bracket
Remove valve cover
remove plugs for guide bolts
lock cam remove cam sprocket
remove guides
do reverse to reassemble.
IN stock
https://www.waymotorworks.com/timing...0-r52-r53.html
Remove valve cover
remove guides
IN stock
This guy's YouTube channel is essentially solely responsible for allowing me to work on this MCS. Just having the full process recorded has been hugely helpful, as these cars are a fair bit more complicated than VWs tend to be (due to the requirement of compactness).
My chain is not making any noise .I thought it would be a lot easier to just keep most everything together and put a little tension on the chain to keep it from coming off the bottom sprocket and slip the guides in from the top. If that is not possible ilI' wait till I get some noise. Thanks for the response. A Curtis
I do use utube for everything I do to the car. I also have the Bentley book. Thanks Andrew Curtis
Spank
11
Apr 9, 2020 02:23 PM
Brea.doyle
Jul 29, 2018 03:39 PM
silence2-38554
Oct 14, 2015 10:08 AM
