R50/53 Cheap Ebay condenser, damaged lower line
Old Mar 3, 2019 | 11:25 AM
r53-06m6's Avatar
r53-06m6
I was in the process of replacing my A/C condenser with an aftermarket ebay cheapo and the lower port looked a litle bit too small. Well I pushed the line in against my better judgement and damaged the yellow part that goes in before the o-ring.
Is this part critical to ensure no leaks in addition to the o-ring or is it some sort of general guide?
If it is critical, is it safe to assume that I have to replace the entire A/C line or can that piece itself be replaced? If that piece can be replaced, what is it called and where do I get it? If I have to replace the entire A/C line, is it a hard job? It looked like a tough job. I couldn't see the line at all from the top at some point and did not crawl underneath to check.
Thanks for any info.
Old Mar 3, 2019 | 11:31 AM
Tgriffithjr's Avatar
Tgriffithjr
That is part of the seal. Not sure if it is replaceable. I would think that if it’s damaged it may leak. I’m assuming you have a vacuum pump to recharge your system. You can try replacing all the O rings, put it back together and then pull a vacuum on the system and see if it holds vacuum. If it doesn’t then you know I won’t hold. But be sure to replace any O rings on fittings that you disassembled to narrow down the leak. Put a little AC oil on the seals when you reassemble the connections.
Old Mar 3, 2019 | 01:16 PM
Tombstone's Avatar
Tombstone
That yellow plastic band is to center up the A/C line to the condenser and there is supposed to be a "new" brown colored o-ring behind the yellow band.Make sure you clean the yellow band (yours appears good in the pics ) first clean with Lacquer thinner or Goof-Off :: but, don't saturate the yellow plastic or it will melt (also helps swell the plastic for tighter fit ) ps: coat both o-ring & yellow seal with a/c oil only.
Old Mar 3, 2019 | 03:18 PM
r53-06m6's Avatar
r53-06m6
Thanks guys. Yes, I do have a cheapo weird vaccum pump from years ago...the one that you connect to your compressor. I have to try and figure out if it works, how to work it, and see if I have all the parts for it first.
That yellow piece has a tear on the right hand side and is a bit warped beyond what the pics will show. At some points while turning, there is a distance between it and the new o-ring due to warpage (not pictured).
Would you still try to reuse it given all of this?
Thanks.
Old Mar 3, 2019 | 05:02 PM
Tombstone's Avatar
Tombstone
Well if you draw down a vacuum and the Snoop bubble leak detector fluid shows a leak ,then you will have to somehow find this from an Auto A/C parts supplier in you area. I looked on line and was not successful in my findings .I buy all of my BMW/Mini Cooper parts from partscontainer on E-Bay and the prices are good...
Old Mar 4, 2019 | 03:03 PM
Tgriffithjr
I would try it. If the yellow part is a guide then it probably doesn’t have much sealing propertes. Just replace the o ring with correct one. If it holds vacuum then your good. If it doesn’t then you’ve only lost some time. Most AC lines only have an o ring sealing them anyway. You can get a complete set of AC o rings of various sizes at Harbor Freight for about $10.
Old Mar 4, 2019 | 09:40 PM
Tombstone's Avatar
Tombstone
Try to avoid the Harbor Freight one's and go with thew OReilly or Pep Boy' brands (SanTech or RapidSeal) ...better rubber
Old Mar 5, 2019 | 04:51 AM
Tgriffithjr
Have you ever used the harbor freight rings? I have and they work fine. Just be sure to get the ones designed for AC systems. They are green. Not everything at HF is junk.
Old Mar 5, 2019 | 07:29 AM
Tombstone's Avatar
Tombstone
Never used them but, I like their Pittsburg impact sockets...
Old Mar 5, 2019 | 12:07 PM
Did you get it to seal? What does the cheap ebay port part looks like? Wonder is the port that inserts is too small or something?
https://www.northamericanmotoring.co...air-first.html
https://www.ecstuning.com/b-genuine-...c/64509181882/
https://www.ecstuning.com/Mini-2005-...h/64508375741/
Looks like a 10.8mm oring is brown one factory and green aftermarket.
Old Mar 9, 2019 | 05:48 PM
r53-06m6's Avatar
r53-06m6
Hey everyone. I didn't see the additional posts.
I ended up using a green o-ring that I had laying around from a previous car. None of the old o-rings would fit and the new one wouldn't either. Tore them all trying.
Here is the condenser that I could never get to fit:
https://cgi.ebay.com/ws/eBayISAPI.dll?ViewItemVersion&item=162405711373&vi ew=all&tid=1816620144006
I then ordered from Rock Auto and got this one:
VARIOUS MFR MC3030101 {#64531490572, CNDDPI3254}
This was the top one on the list with a heart in it. To my surprise, it arrived bent. I have never had any problems like that from Rock Auto.
I was so fed up I stepped on the condenser to see if I could straighten it out and not bend fins prior to having to go through the hassle of returning this condenser too. It was just a bit warped when I was done but the gamble paid off. I was also shocked that the condenser shipped pressurized. Not sure if that was normal.
Anyways, no leaks so far.
MINIMarauder
Dec 14, 2006 10:15 AM
Bydgoszcz
Tires, Wheels, & Brakes
12
May 30, 2006 08:25 PM
CabMike
Apr 17, 2006 12:51 PM
MINIMAXXNC
Jul 15, 2005 11:19 AM
mikealie
May 10, 2005 06:40 AM
