Popping sound when stopping
Old Feb 24, 2019 | 11:29 AM
Apexlate's Avatar
Apexlate
Hi all, I have an 05 MCS that is making a metallic popping sound when I apply the brakes to stop in my garage. It seems to only happen at very slow speeds. The brakes look fine and work great. Any ideas on how to cure this?
Old Feb 24, 2019 | 12:11 PM
ItsmeWayne's Avatar
ItsmeWayne
The brake pad linings may be worn out. You better take off the wheels and inspect all the pads and look for loose attachment bolts.
Old Feb 24, 2019 | 05:58 PM
gresh's Avatar
gresh
How many miles.? You could have a lose brake caliper. Pull the tire and try to shake the caliper. You could actually do it by turning the wheel to one side and doing it from the back. There are 2 screws that hold the caliper to the bracket and two screws that hold the bracket to the car. Check them both for tightness. And as mentioned before, check the brakes for wear and proper install.
Old Feb 24, 2019 | 06:32 PM
Apexlate's Avatar
Apexlate
About 130,000 miles. I inspected pads, rotors and did a visual inspection in November when I replaced the struts. I have no idea when the rotors and pads were done because I have only had it a year. I thought it was one of the retaining springs but they were tight. I did not check the caliper bolts and am a little ashamed I hadn't thought of that. Could the slides be sticking?
Old Feb 24, 2019 | 07:23 PM
gresh's Avatar
gresh
did you recheck your struts. If it just a single pop, then I could be the struts are not tight or the calipers are lose. If it is a continuous thing until the car stops, then lose calipers or pads. Did it pop before you did the struts?
tommyebrown
Cooper (non S)
21
Feb 1, 2012 08:40 PM
boognish
Detailing 101
Sep 25, 2006 11:20 AM
COOP151
Dec 23, 2005 07:33 AM
saakey
Oct 20, 2005 02:40 PM
JerryTheTiger
Jan 17, 2004 08:30 AM
