R50/53 Fuel filter float problem
Old Feb 19, 2019 | 04:06 PM
Robert McAllister's Avatar
Robert McAllister
Hello all
Since I purchase an2005 Mini Cooper s converable I have been trying to fix it here and there! I have ran into a problem with the fuel filter replacement problem. I replaced the filter but now the float car connected to the filter base came off and now I am unable to reconnect it!! Does anyone know how to reconnect it for the space to work is way to tight or recommend someone who does repairs in south jersey besides the Mini dealer?
Old Feb 19, 2019 | 08:52 PM
Tgriffithjr's Avatar
Tgriffithjr
Do you mean float bar?
Old Feb 20, 2019 | 12:50 PM
Cease's Avatar
Cease
Run down fuel or carefully siphon the fuel out. Then open the access under the rear seat and use a flashlight and a wire hanger to dig out the wire. I almost did the same thing while replacing my filter last week.
Old Feb 20, 2019 | 01:18 PM
+1^ just be careful with the fumes and everything.
Then clip it on to the old housing, should look like this when attached
DIY for the future.
https://www.northamericanmotoring.co...er-change.html
Old Feb 21, 2019 | 08:49 AM
Robert McAllister
The float bar had come all the way off, it appears that the angle to reattach does not match up? Why I don’t known. I thought it was some how disconnected from something else but not so and unable to reconnect with minimal space available.
Old Feb 21, 2019 | 09:05 AM
You might just have to pull the whole thing out and reattach it.
Old Feb 21, 2019 | 09:21 AM
Tgriffithjr
That’s what I was going to say. The metal arm snaps into place on the plastic fitting and it can be brittle from exposure to fuel. Best to remove the unit. I hate to say it but the little tabs on the plastic arm may have snapped off. If that happened it would be difficult to reattach the float arm. You might be able to tie the arm onto the plastic arm with some small copper wire strands from an electrical wire.
Old Feb 22, 2019 | 08:20 AM
Soul Coughing's Avatar
Soul Coughing
FYI, i have a brand new fuel filter assembly, with float and all electrics, minus the filter cap I could sell you for much less than the going rate of 190$. Let me know if you need it as it's just sitting in my storage.
G3NSM0R3S
16
Jun 15, 2025 12:51 PM
Classic Mini Talk
Feb 6, 2018 11:47 AM
EODguy
Feb 16, 2012 05:31 PM
Jerseygirl
24
Sep 15, 2003 06:39 PM
