R50/53 19% pulley!!!!!
Old Feb 18, 2019 | 03:48 PM
meanmini135's Avatar
meanmini135
19% pulley!!!!!
Ok i know this topic has been beat to death but I want to know if I should go with a 17-19% pulley. My car currently has a CAI and a catback exhaust, I plan on getting a tune sometime after the pulley swap. Also what all is needed for this install, can I do it in my driveway? Ive done a pulley swap on a Grand Prix GTP and I had to use a pulley puller.
The car will mostly be used for street and highway pulls, I want the most power possible, my goal is to beat my brothers SRT4.
Any and all advice welcome, I just got my mini on sat and dont know too much yet.
*edit
Car allready has a WMW 15% pulley installed, what mod would you guys reccomend next?
Old Feb 18, 2019 | 04:46 PM
IQRaceworks's Avatar
IQRaceworks
For a street car, go with a 17% pulley. If it was a track car, I would say 15%. A 19% pulley builds too much heat in the supercharger, spins it to fast, and wears out your supercharger belt really quick. A 17% is perfect for the street...you will definitely feel the difference. Don't worry about a tune unless you really want to spend $600+ is kind of a waste of money. I would wait until you do more mods like a header, and injectors. But really......for the money you are going to spend on a tune....you don't see a huge boost in power. But, that's up to you.
Yes, you can do it in your driveway.......but rent/buy one of the special pulley pullers (it's not the same type you can rent at the autoparts store). If I remember right, if you buy a pulley from Way Motor Works, they will "rent" you the puller....they just charge you for it until you return it, then you get a full refund. It's a must have for these pulleys and the tight space you are working in.
Buy a 17% pulley!
Old Feb 18, 2019 | 04:50 PM
BlwnAway's Avatar
BlwnAway
For street...
17% without W/M
19% with W/M
You can do it in your driveway and you will need the specialty puller, along with a new belt and spark plugs.
You can check with Detroit Tuned or Way Motor Works for the parts or a package, if you don't want to source everything separately.
As long as the SRT-4 is stock, you may still have difficulties in the straights with just a pulley and a tune, but you'll mess him up in the twisty's.
Old Feb 18, 2019 | 06:02 PM
meanmini135
Does W/M stand for water/meth?
I would consider installing a meth kit if it means more power
Old Feb 18, 2019 | 07:03 PM
BlwnAway's Avatar
BlwnAway
Yes, and it can give you more power of if yout tune for it.
But.. Be forewarned, if you're gong to tune for W/M you need to use a more expensive and reliable kit.
Without tuning for it, the benefit is strictly to remove some of the extra heat generated by the 19% pulley over the 17%.
Without the W/M there's a good possibility the extra boost of the 19% pulley will be negated by the extra heat, and may even make less overall power than the 17% pulley alone.
Just something you need to realise going in.
Old Feb 18, 2019 | 07:20 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
For what you want I would say go with a 17% as that is more ideal for what you want. The 19% is good for a real short run if you were like AutoX only. It gets low end, but runs out of quick and builds too much heat along with overspinning the blower and water pump. That is why most manufactures don't even make the 19% anymore.
You HAVE to have the correct puller to pull the pulley otherwise you will likely damage the supercharger.
https://www.waymotorworks.com/pulley-puller.html
We offer 15,16,or 17% pulleys with the correct belt and plugs
https://www.waymotorworks.com/wmw-pulley-package.html
I do remember that you said this car had a roll cage so I would also suggest verifying it doesn't have a pulley already as that would be odd to not have done, but have a cage??
For tuning we suggest waiting till you have done all your mods first before doing a tune as changing after a custom tune will require retuning.
Old Feb 18, 2019 | 08:08 PM
meanmini135
Well I just checked and it looks like it has an aftermarket pulley, now I just need to figure out which one it has.
*It looks like a WMW 15% pulley!
Old Feb 18, 2019 | 08:13 PM
meanmini135
Old Feb 18, 2019 | 08:30 PM
WayMotorWorks
Vendor
*It looks like a MWM 15% pulley!
Great that is a good savings for you, and if you do swap you won't need a puller as that one comes apart.
Old Feb 18, 2019 | 09:01 PM
xsmini's Avatar
xsmini
I'd leave the 15% and get a +2% crank pulley....... thats what I did.
Nik
Old Feb 18, 2019 | 10:33 PM
meanmini135
How much hp would headers net me? I already have a scorpian cat back but it's too quiet for my taste
Old Feb 19, 2019 | 04:16 AM
Tgriffithjr's Avatar
Tgriffithjr
Read the thread below this one; it’s about headers.
Old Feb 19, 2019 | 04:56 AM
IQRaceworks
Nik
But then you still run into the same issues as you would with a 19% pulley.....spinning the SC and waterpump to fast, building too much heat.
Old Feb 19, 2019 | 05:32 AM
Soul Coughing's Avatar
Soul Coughing
I've run a 19% pulley since 2006 and haven't had any issues with the water pump or melting anything. When i replaced the water pump for preventative maintenance, the bearings were fine, there was no play, and I didn't see any cavitation on the impeller . I've never overheated and i've pushed the car to its 7.2k redline with the GIAC software many times. While it's probably not ideal for track work, the setup on the street is awesome.
Old Feb 19, 2019 | 06:24 AM
SupeR53's Avatar
SupeR53
I'm running a 15% with a 2% crank pulley with no problems, 163k miles and the SC is still pumping just fine.
Old Feb 19, 2019 | 05:04 PM
AngelicVictoria's Avatar
AngelicVictoria
Just here to say @meanmini135 has a mean-looking Mini! Hehe! Keep up the great work! I'm sure you'll find what's best for you
Old Feb 20, 2019 | 12:51 PM
meanmini135
Thanks lol
Old Feb 20, 2019 | 11:07 PM
meanmini135
Nik
But wouldn't that equal %17 percent??
Old Feb 20, 2019 | 11:09 PM
meanmini135
Do you have any dyno numbers? I would love to see hp numbers for 15% 17% and 19% with CAI and exhaust
Old Jun 10, 2023 | 09:40 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
I know it's an old post for for people looking into a 19% pulley......
I too have run mine for 6months now and the car makes 18psi max. I've run every single pulley now available and I can honestly say, DO A 19% ON A MANUAL if you want the best bang for your buck run no hotter but yet makes more and max boost at lower rpm and i still shift at 7200.. it DOES not overspin the waterpump or overheat iat's.. sure , it's not ideal for track use and extended high rpms but for the street and back road pulls or stop light to stop light , ITS PERFECT !
I also tried a 20% BUT that made NO more boost and I DID start to see hotter iats without extra boost .. though it made max boost sooner it DID NOT make more max boost.. imo the 20% pulley is made for the automatic cars that can't get into that sweetspot in the rpm range..
i went with the wmw 19% pulley package and it along with my sc I ported , its not much less boost than my fully spun sprintex soooo , yea. Go 19% and stop believing all the false " I know somebody who knew somebody " b.s...it's safe , even driving in 100'F stop n go traffic , its fine...
yea you need a few supporting mods but that imo is common sense..colder plugs , shorter belt and imo absolutely 380cc injectors.
Now get boosting !
C-Lop
Mar 24, 2010 12:05 PM
meb
Apr 24, 2005 01:26 PM
Herby74
Feb 1, 2004 01:34 PM
efcmini
Aug 31, 2003 09:48 PM
Mjolnir
Apr 7, 2003 06:35 AM
