R50/53 Oil Filter Cap.
Old Feb 17, 2019 | 10:38 AM
CRC's Avatar
CRC
Oil Filter Cap.
I've just finished doing an oil change on my '06 R50 daily driver, @ 195000 miles. As usual, and always, the only pain the **** is getting the oil filter cap to screw on without cross threading the darn thing or ruining the "o" ring. I have put 160000 of those miles on this car, and done between 30 - 40 oil changes. Every time it takes multiple attempts to get the bloody cap back on!
Old Feb 17, 2019 | 03:41 PM
bugeye1031's Avatar
bugeye1031
Moderator
I have the same issue. Way more "fiddly" than it should be. The only thing that I've been able to do, and it doesn't really solve the problem, only helps a little...is to mark the start of the threads on the cap so that I avoid wasting my time feeling for the start of the thread engagement half a turn before they'll engage. Still not my favorite thing to do.
Old Feb 17, 2019 | 05:06 PM
Tgriffithjr's Avatar
Tgriffithjr
Why are you having issues? An 06 should use the newer style filter. You don’t have a spring do you? The spring and cage was eliminated after 7/2004. It should screw on easily without pressure. Make threads are clean and put a little grease on them and the o ring. I use petroleum jelly.
Old Feb 19, 2019 | 07:28 AM
MINI33342's Avatar
MINI33342
I always fit the filter on first. Then put the filter into the canister. By placing the filter on first it enlarges the hole just a bit making it easier to start the canister.
Old Feb 19, 2019 | 08:13 AM
Tgriffithjr
I find it easier to put it into the cap first.
Old Feb 19, 2019 | 12:18 PM
Cap first then search / feel the threads and line up, then screw on slowly and your done.
Old Feb 19, 2019 | 12:26 PM
Tgriffithjr
Old Feb 19, 2019 | 01:20 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I am with you on this. I always insert the filter into the cap first. And with the M7 strut brace making it even more difficult to know for sure by feel that I have the thread hand started without cross threading. If you are **** and not care about the consequence of X-threading you can mock us.
The thing is it is very hard to tell by feel as there is so much resistance due to the diameter of the cap and soft AL alloy threads, plus the drag of the (oiled) o-ring. Not able to see adds to the agony.
Old Feb 19, 2019 | 03:49 PM
Capt_bj's Avatar
Capt_bj
doing GEN1 changes since 03
I find using firm pressure down on the can while trying to get it to grab is the secret
put the filter in the can and press as far as it will go - lube the o-ring, then position the can and with firm pressure down, turn ... it will catch and I can tell when the o-ring begins to touch by the feel . . . .
yhe fit is SO tight it always needs a wrench for a final ugh ...
Old Feb 20, 2019 | 04:20 AM
CRC's Avatar
CRC
I always put the filter into the cap first, pressing it down as far as it will go, and lube the "o" ring with fresh oil. I've tried the procedure as described by ECS above, and sometimes it works and sometimes it doesn't. It could go on at the first attempt or take 5 - 6 tries (and a lot of Anglo Saxon cursing). I also check that the cap is going on square by using a flashlight and small inspection mirror to make sure that the cap is not cross threading.
Old Feb 20, 2019 | 06:56 AM
ramjet77's Avatar
ramjet77
I'm surprised that after all this time complaining about the difficulty of reinstalling the filter cap, no one has come up with a remote filter adaptation to simplify this annoyance. I've been fretting about this since I bought my car new in 2003. I'd pay for a remote filter set up.
Old Feb 22, 2019 | 09:43 AM
JABowders's Avatar
JABowders
Veteran: Army
Spin the cap backwards (loosen) a few times, feel the threads align (you can feel the cap index into the threads) then tighten it up.
Motor On!
Old Feb 28, 2019 | 08:44 AM
+1 thats a good trick also i used.
Old Feb 28, 2019 | 05:23 PM
mslatter's Avatar
mslatter
I did my first change about a month ago. I was surprised how difficult the filter was to install. And I don’t mean just threading the cap on (though that was a thing, too). I mean just fitting the filter into the cap, and onto the engine. It seems like the hole in the filter is too small. I had to use condemnable force and twist to get it on the cap and the engine, actually folding the filter material into the hole as it went on. Makes for a tight fit, I guess. I even stopped mid-way and hit the internet to learn how stupid I am, but (for once) turns out I’m not stupid. Others have had the same complaint. 2006 JCW if that matters, and dealer-purchased OEM filters.
In any case, thanks for the tips. They’ll help.
Old Feb 28, 2019 | 06:03 PM
Tgriffithjr
Are you sure you didn’t have the wrong filter. It changed designs in 2004.
Old Mar 1, 2019 | 12:24 PM
mslatter's Avatar
mslatter
The dealer looked up the part number by VIN, so I trusted he'd get the right one. It's 11427512446, which is also the part number on realoem.com. I'd be delighted to learn that there's a better fitting filter element. I'm not the only one (end of this thread) https://www.northamericanmotoring.co...r-numbers.html
Old Mar 1, 2019 | 12:26 PM
Tgriffithjr
I have an 06 and the filter I use has the built in cage. It snapped right into the cap with little effort.
Old Apr 6, 2019 | 09:41 AM
CRC's Avatar
CRC
Just finished another oil change on the Justa, and this time the bloody cap went back on first time with very little effort. %$&#@*^+! Mileage is just below 198000 now, and I should hit the 200000 mark in about 6 - 7 weeks.
trwxxa
Nov 23, 2016 01:28 PM
jay80424
Nov 6, 2014 07:03 AM
mckchr67
Sep 5, 2013 07:26 PM
marucusu
Want to Buy - All Other Items (archive)
Jun 16, 2008 02:38 PM
