Oil light keeps coming on
Old Feb 5, 2019 | 06:16 AM
Hairy W Bush's Avatar
Hairy W Bush
I just bought this 2011 Clubman s and the oil light keeps coming on I fill it every you like 50 - 100miles. Yet when I check it after it's been sitting for a few hours the dipstick is plenty full. But it goes off when I add oil but does this mean my oil sensor is bad
Old Feb 5, 2019 | 09:18 AM
Hairy W Bush
So apparently it's actually the half yellow service engine soon light...
Old Feb 6, 2019 | 04:37 AM
Tgriffithjr's Avatar
Tgriffithjr
Are you actually having to replace oil every 50-100 miles? If so you either have a serious leak or you are burning oil. Don’t overfill with oil as that can cause foaming which can potentially starve the engine if oil pressure.
Old Feb 6, 2019 | 06:05 AM
Hairy W Bush
It has a leak and I saw some smoke when I was buying it. I had never seen that light before and I'm astonished that there are 2 different check engine lights. I managed to pull the code when it came back up again and it is a P0087, indicating a fuel issue, something I would rather have than anything to do with oil. I'll try and do an oil change this weekend. I actually haven't noticed
​​​​​​ any smoke since I bought the high mileage oil. Maybe that's what it needed.
Old Feb 6, 2019 | 07:07 AM
Tgriffithjr
Have you done a compression test? That will tell you what your rings are like.
Old Feb 6, 2019 | 09:07 AM
Hairy W Bush
No I regret not buying one at the swap meet last year
Old Feb 6, 2019 | 09:25 AM
Tgriffithjr
You can get an inexpensive set at harbor freight or borrow one from auto zone or oreilly.
flav
Sep 29, 2022 11:28 AM
aem421
Oct 24, 2007 08:56 PM
aem421
Sep 19, 2007 06:51 PM
lisdexic driver
Oct 14, 2006 10:31 AM
sanddan
Tires, Wheels, & Brakes
Apr 23, 2004 08:34 AM
