Work to be done
Old Jan 29, 2019 | 04:18 AM
Stella11's Avatar
Stella11
Work to be done
I have a 2003 R53 that we just bought for our son. It is a single owner with 72,000 miles. He does not have his license yet so for right now it is sitting in our garage, here is my question, while it has been parked there is oil leaking from the front of the motor. I don't think it is the CPS o-ring because that is above the oil line. What else could be?
Thanks in advance to all!
Old Jan 29, 2019 | 07:30 AM
cooper48's Avatar
cooper48
Oil leaks on older MINIs are part of the ownership conundrum. The CPS o-ring will spew oil just about everywhere on the front of the block which makes it difficult to narrow down the actual source. If the leak is lower, then the oil pan/plug would be a natural spot to look. Another would be the front engine seal (behind the crankshaft pulley). Repair on all of these is not difficult if you're patient and handy with tools.
Old Jan 29, 2019 | 09:03 AM
Zsm's Avatar
Zsm
Congrats to you and your son on the new to you R53. Great car to learn to drive and work on as a first car. It's what we did nearly 3 years ago. As cooper48 wrote, oil leaks are a part of the ownership experience. If you have some records of previous services, that may help get you started in determining where to begin your oil squelching quest. Are you (and your son) planning to tackle this on your own or are you planning to have someone service it?
If you haven't already done so, put a piece of cardboard down under the motor to see where the oil is concentrated in. Then, lift up front of car and clean up the bottom of the motor and then watch to see where the oil is leaking from. A 16 year old car is gonna need some TLC no matter who maintained it previously. My guess would be the oil pan gasket. Not hard, but you do have to drop the A/C compressor and separate the lower motor mount.
Lots of threads here on oil leaks so have a look around and let us know what you discover and find.
Old Jan 29, 2019 | 09:05 AM
Stella11's Avatar
Stella11
Those were the three I was thinking. We are planning on doing all three when it's not -20° out there!
Old Jan 29, 2019 | 09:08 AM
Stella11's Avatar
Stella11
If you haven't already done so, put a piece of cardboard down under the motor to see where the oil is concentrated in. Then, lift up front of car and clean up the bottom of the motor and then watch to see where the oil is leaking from. A 16 year old car is gonna have some needed TLC no matter who maintained it previously. My guess would be the oil pan gasket. Not hard, but you do have to drop the A/C compressor and separate the lower motor mount.
We bought it so him and I can work on it together. I am somewhat handy and he is very mechanical so I think between the two of us and with YouTube help we should be able to tackle it.
Old Jan 30, 2019 | 09:37 AM
Derek86's Avatar
Derek86
Mod Mini makes some fantastic repair videos on YouTube.
Old Jan 31, 2019 | 07:01 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
No way to guess what is leaking without seeing it. Crawl under it and follow the oil from the highest point down as you know it doesn't leak up.
Scooby Doo
Nov 16, 2018 12:56 PM
chows4us
62
May 11, 2006 02:36 AM
Pat_Cooper
May 20, 2005 08:19 AM
kite-surfer
Jul 8, 2003 06:28 PM
