Rear hatch popping incessantly r56
Old Jan 19, 2019 | 09:07 PM
Derrick A. Lundberg's Avatar
Derrick A. Lundberg
Hey, I have a strange problem and I'm hoping it's something I can fix without buying a new key fob.
my rear hatch doesn't have a working button, but the jet fob works on command. However, lately it has been unlatching on it's own. The pressure of a shutting cardoor is enough to half latch it, but it will give me the rear hatch warning always. I've tried to find a pattern with it but it usually seems to do with when the door opens or when the car is unlocked... I'm hoping there's a fuse I can replace easily or something.
Any thoughts?
Thank you
Old Jan 20, 2019 | 07:23 AM
Tgriffithjr's Avatar
Tgriffithjr
Sounds like the latch is either not shutting completely or wearing out.
Old Jan 20, 2019 | 08:20 AM
Derrick A. Lundberg
I have considered that it is potentially wearing out, but it was replaced about a year ago, as the last one locked shut and wouldn't respond to the fob.
It does close completely. Then I'll open the door, sit down and then hear "pop" as the hatch opens.
I did have about a couple of weeks of no involuntary popping after discovering that the latch was loose and moving around on it's adjustable bolts
Old Jan 20, 2019 | 12:33 PM
Tgriffithjr
Sounds like it’s loose again. Or not latching completely even though it may seem like it’s solid.
Old Jan 20, 2019 | 06:09 PM
vetsvette's Avatar
vetsvette
Moderator
I agree. Had a similar problem myself. Dealer replaced the latch and once I learned not to be too gentle when closing it I never had a recurrence. It's been working fine for more than two years now.
Old Jan 21, 2019 | 05:30 AM
my_wifes_mini's Avatar
my_wifes_mini
You can replace the button on the back of the car. You have to do the whole housing and rear trim piece. Its an easy plug an play as long as you are OK with chrome. My rear handle stopped working and I just couldnt live with key popping it everytime, so I replaced it.
frappucino
Apr 6, 2018 04:08 PM
Scooter162
Oct 25, 2014 06:09 AM
Garyt
Oct 8, 2014 10:51 PM
ronmichael
Feb 6, 2010 07:49 PM
gordyhulten
Jul 30, 2009 04:40 PM
