Coolant tank leaking
Old Jan 19, 2019 | 05:28 PM
6erminisgirl's Avatar
6erminisgirl
2006 mini S 65,000 miles purchased used recently. After 1 week of driving 30 miles daily the coolant tank leaked and blowing steam. Car runs cool never hot and with no smoke. Thoughts?? Coolant tank plastic and brand new.
Old Jan 19, 2019 | 05:37 PM
cooper48's Avatar
cooper48
This is a common problem with older MINIs. Best bet is to replace it with an aluminum tank which is less prone to leaks. Check eBay or Amazon for the best pricing.
Old Jan 19, 2019 | 06:08 PM
haarbulary_battery's Avatar
haarbulary_battery
yeah, just replaced mine on my 05...was hissing. picked up a replacement on amazon for $30 shipped with prime 1 day shipping
Old Jan 19, 2019 | 10:14 PM
Zsm's Avatar
Zsm
Did you replace the coolant cap too? If not, I’d be suspicious of its ability to hold pressure.
Old Jan 19, 2019 | 10:52 PM
Fly'n Brick's Avatar
Fly'n Brick
I replaced mine with a stainless steel tank and the OEM cap works just fine.
PS: It takes a very small hand to get the bottom hose unhooked and re-connected.
Old Jan 20, 2019 | 09:07 AM
buzzsaw's Avatar
buzzsaw
I too replaced my functional yet aging oem plastic tank (as a time item) with a metal one. They now can be found on ebay for around $50 +or -. Wouldn't hurt to buy a spare oem cap. They cost about $10--cheap insurance. I always keep a spare in the boot. Found out that if you keep the coolant level just above the center stand pipe, you won't have any problems. It's an easy DIY ( info online) but as Fly'n Brick mentioned it takes small hands to secure the tank to the support bracket. Good luck.
Old Jan 20, 2019 | 12:20 PM
6erminisgirl
thanks for all the info. I am definitely going to upgrade to aluminum. I have been reading a lot about it. The sad truth is I noted the temp gauge began to climb today while sitting idle after driving about 10 minutes and the fan was on and it continued to climb quickly. I shut the car off before it got too hot. Small amount coolant leaking from coolant tank. I am not going to lie by this makes me very skeptical of head gasket. Love the car. It’s got soul but hopeful it’s not a huge expensive fix.
Old Jan 20, 2019 | 12:30 PM
Tgriffithjr's Avatar
Tgriffithjr
Coolant temperature is dependent upon pressure as well as proper fill level. Even if you aren’t very low on coolant your temp can climb with a pressure leak as you have.
Old Jan 21, 2019 | 04:54 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Where is the coolant leaking from?
The cap?
​​​​​​​The center seam of tank?
Hose connections?
Zsm asked if you replaced the coolant tank CAP as well. Did you? Bad caps are a very common failure point, no matter if your tank is plastic or metal. If they can’t hold the pressure, you will overheat.
Emincee1012
Jul 12, 2017 12:10 PM
bunce
Aug 15, 2008 07:59 PM
XAlfa
Nov 30, 2004 03:19 PM
2Cool
May 3, 2004 03:44 PM
