R57 Forge Turbo Blanket Install
Old Jan 17, 2019 | 05:55 AM
mikeandtricie's Avatar
mikeandtricie
Decided to try and cut down on the heat melting our scoop so I installed a turbo blanket. Got them on sale from ECS over Christmas. Product came in a bag no instructions, but looked pretty straight forward. Hardest part was to remove and install the three bolts on the radiator side. My suggestion is to clean them before installing them again. On the R57 you need to remove the sensor completely and loosen the sensor bracket and move it out of the way. R59 you just unplug the sensor and feed it through. Both needs the OEM heat shield removed and for the first few drives it smokes like crazy. Just open your hood and windows and air it out after each drive until it stops smoking. Looks cool and feels cooler, but it's also winter here ;-).
R57 JCW
R59 JCW
Old Jan 17, 2019 | 08:36 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Looks like a copy of the older Alta / Perrin turbo blanket.
Not sure you have it installed 100% correctly... Looks like it should be tucked between the hot side turbine housing and the oil / water lines - not sitting on top of the oil fitting like that. I would be worried about the oil and water lines getting too hot.
Old Jan 17, 2019 | 08:44 AM
mikeandtricie
I'm open to suggestions. Again, it had no real instructions. CS just says it goes over Turbo and is a bolt on replacement for OEM. So what you're saying is I should tuck the right side of the blanket in?
Below is what Forge has on their site:
Old Jan 17, 2019 | 09:03 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The install instructions can be found here, under the "Downloads" tab:
https://www.forgemotorsport.com/Turb...uct--1615.html
Take a look at this picture of the Alta blanket:
See how it tucks nicely between the turbine housing and the oil line? I would try to get the Forge blanket into a similar position.
Old Jan 17, 2019 | 09:14 AM
mikeandtricie
Yeah, those are the instructions I got from CS, "Remove the bolts and shield and bolt on". I get what you're saying, problem is the Forge is a little longer on the right than the Alta. I'll try and see if there is any room to tuck it down.
Old Jan 17, 2019 | 10:46 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I appreciate the posting. I have been eyeing that thing, since the price seems reasonable.
Old Jan 17, 2019 | 06:26 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Looks good. We have shipped out a few but this is the first one someone took a pic of after install
https://www.waymotorworks.com/forge-...-cooper-s.html
Old Jan 18, 2019 | 11:38 AM
blue al's Avatar
blue al
In my garage waiting for turbo upgrade
hope it has some slack
Old Feb 7, 2019 | 01:51 PM
Did you ever get the turbo installed? And try it yet?
Old Feb 8, 2019 | 04:27 AM
mikeandtricie
Yes, I ended up tucking the right side in so it doesn't cover the hoses. One thing I noticed on our R57 it smoked like crazy for the first few drives where I felt a little uneasy. I was told its normal and it went away. On our R59 it didn't smoke as much. I was only able to see it if I popped the hood. Its been cold here in NC so I couldn't really tell you if it reduced the heat, but definitely looks good.
Old Feb 8, 2019 | 06:22 AM
Ok, thats good. yes the first time you run it bakes in location a little bit then hold that shape. Thanks for the update.
Old Mar 28, 2019 | 05:24 PM
SNOOPYS_MINI's Avatar
SNOOPYS_MINI
Just ordered the Forge blanket from you. :
Old Mar 29, 2019 | 05:14 AM
Thanks for the continued support!
Old May 30, 2019 | 03:43 PM
5310mini's Avatar
5310mini
I purchased the Forge blanket and while installing the top right bolt, the faster tore right through the fabric. In addition, the fitment on the lower section wasn't good either. Looks like it was made a bigger turbo. I contacted ECS and they were willing to allow a return or a replacement. But since I re-installed the Mini metal cover over the blanket to cover the tear, returning or a replacement, wasn't an option. I asked to have my purchased discounted but they declined. So beware when you install one. And yes it didn't reduce the amount of heat.
Old May 30, 2019 | 05:32 PM
SNOOPYS_MINI
Serious?
First, of course it doesn’t fit like factory. It’s a turbo blanket. Duh.
And why should they give you a discount?
Have you ever done a mod to a car before? Do you realize that making modifications to a car means that you are modifying ?
Seriously don’t get your post or why putting down a great product. Maybe put on a fresh pair of panties and leave your credit card in your purse next time.
Sorry, but really don’t get your post. :(
Old Nov 1, 2023 | 03:21 PM
8Gates_BlueBeast's Avatar
8Gates_BlueBeast
Misplaced the bolts and need to order new hardware. Does anyone know the bolt size I should get to install the blanket?
Old Nov 2, 2023 | 05:10 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I would stick with the OEM bolts, since they are galvanized to prevent corrosion.
https://www.realoem.com/bmw/enUS/sho...diagId=11_4558
https://www.ecstuning.com/b-genuine-...t/07147543920/
Csbdr
R60/61 Cooper S Drivetrain
Dec 29, 2019 12:49 PM
BMC_Kid
Sep 10, 2016 01:45 PM
Tuesdayclub
Nov 20, 2015 07:08 AM
sukonthorn
General Mini related Ads
Mar 16, 2015 09:46 PM
Emnotek
Jan 18, 2014 09:30 AM
