ALTA Thermal Turbo Blanket
Old Jan 18, 2014 | 09:30 AM
Emnotek's Avatar
Emnotek
ALTA recently released a Thermal Turbo Blanket for the 2007-2013 Mini Cooper S Gen2 Turbo. Details below...
MINI Cooper S Gen2 ALTA Thermal Turbo Blanket
ALTA Performance Thermal Blankets for the Gen2 MINI Cooper S improve response and power by insulating exhaust components from losing critical heat, increasing exhaust flow, all while significantly lowering under hood temperatures.
Performance
Unlike the factory stamped metal shroud, The ALTA turbo thermal blanket fits snugly around the turbine housing and exhaust manifold of your MINI to keep nearly all radiant heat away from your intake and other engine components. The high temperature woven silica lining increases durability, improves thermal resistance and protects other parts from wear and scratching.
For those looking for the ultimate in protection, the ALTA Thermal blanket can be installed over the OEM shield as well.
Design
Designed for extreme temperature environments the turbo blanket features 3 layer construction. An outer cover made from Silicone Impregnated Fiberglass (rated to 500F continuous), an inner layer made of Calcium Magnesium Silicate Insulation (rated to 2000F continuous) control heat while Silica insulation (rated to 1800F Continuous) is used to contain the inner layer.
Installation
Formed stainless steel eyelets allow you to simply attach the Alta thermal blanket to the OEM mounting holes. This makes the installation easy and allows for other aftermarket shields to be used in conjunction.
Protection
The factory metal shroud has zero heat protection for your turbochargers oil feed line. Over time this major flaw causes the formation of carbon solids inside the oil line restricting oil flow to your turbo. This unavoidable and common problem is virtually solved by installing an ALTA Turbo Thermal blanket with its physical heat barrier between the turbine and oil line.
Fitment
The shape of the ALTA Turbo Thermal Blanket is specifically designed to fit over most aftermarket turbo and downpipes, as well as the stock parts.
bahman
Nov 15, 2019 05:45 AM
Mb460
Sep 14, 2015 05:50 AM
schwac2
Sep 10, 2015 07:24 AM
