Navigation & Audio 2003 H/K Audio sounds coming from right side
Old Jan 14, 2019 | 09:21 AM
Wildrider's Avatar
Wildrider
Hello all! I have a 2003 R53 with the H/K System. I swapped the radio for a later 2006 factory HU to get the MP3 CD capability. It works but the sound seems like it's coming from the passenger side mostly. If I open the door and get my ear near the tweeter and mid on the driver's side, it is playing, but not at the volume on the right. I have played with the eq settings, switched "driver only" on and off and it's still the same.
I have been considering adding the GROM bluetooth to the system but if the H/K amp is going bad, then I would just replace the entire system. So my question is, does this sound like a HU, AMP or Speaker issue? I could replace the HU with my original and see if that solves the problem. If it doesn't then what?
Old Jan 14, 2019 | 10:48 AM
ssean72's Avatar
ssean72
If you are having issues with the amp I have one I will sell you at a good price
Old Jan 14, 2019 | 11:00 AM
bee1000n's Avatar
bee1000n
Not an expert, but there is a little troubleshooting you can do (and may have done already): Set the radio to something other than Mini H/K. Mini H/K uses the rears like subwoofers, so you don't want to use that to check your speakers.
Then, adjust the balance and fade to the extremes - all the way to the left and all the way to the front, then left/back, right/back, right/front.
This will at least help determine exactly where sound is being produced.
(maybe you've already done this)
To test if it's a speaker issue, you could pull out the front speakers and swap them side-to-side. If the issue persists, then you know it isn't the speakers.
I'm having an issue like yours where the front-left mid is barely audible, but I've taken the lazy and free way out and just adjusted the balance/fade to compensate.
Old Jan 14, 2019 | 11:30 AM
Wildrider's Avatar
Wildrider
I like the idea of swapping the speakers from one side to the other. One thing that dawned on me is that it could be the mp3 file itself. I will try a real OEM CD (if I can find one) and see what that sounds like first. As far as balancing, I switched out of H/K mode on the EQ and adjusted the balance left to right. I had to move it almost completely to the left to hear the left side speaker.
Old May 3, 2019 | 07:48 PM
Alpha Motoring's Avatar
Alpha Motoring
Almost confident to say your amp is going south.
one73ronin
Jun 20, 2017 09:49 PM
mona5255
Dec 14, 2014 02:35 PM
2003minicooper
Nov 22, 2012 12:37 PM
Bradg33
15
Oct 7, 2011 07:09 PM
MC2005s
Apr 17, 2011 08:27 PM
