ABS-DSC Stability Control MK60 code?
Old Jan 10, 2019 | 04:51 PM
Tombstone's Avatar
Tombstone
Need help figuring out how to single out ABS-DSC Stability Control MK60 code (fault 1 ) on a 2006 R53 "S" ? Scanned my R53 with the Schwaben Scantool, just purchased by ECS Tuning and this code shows up. The TPMS light along with the amber triangle with CCW arrow shows up on tachometer. These two lights have been on solid for a couple weeks and the DSC button on console (push & hold for 3-seconds ) will not clear these lights? Is it the ABS pump, ABS Module, or TPMS wheel sensors? Any help would be appreciated. Thanks...
Old Jan 11, 2019 | 11:39 AM
Check the pump connection and the plug , its up under the passenger side near the window cowl. Bet its the ABS/DCS unit I would check to see if an animal chewed the wires, then also check the fuse.
Old Jan 11, 2019 | 11:40 AM
You can see it on the left with all the small brake lines running to it.
celticfc
Aug 20, 2015 01:54 PM
HowardPM
DC Metro MINIs (Archive)
15
Feb 15, 2007 12:05 PM
tvacc
Electrical
Feb 3, 2007 09:35 AM
gizzer777
24
Sep 15, 2006 02:35 PM
Brownielocks
Sep 9, 2002 08:36 AM
