R55 Clutch shutter
Old Jan 7, 2019 | 12:33 PM
goody211's Avatar
goody211
Clutch shutter
Hi, I have 105k miles on my 2009 Clubman S and lately I've noticed a shutter when taking off in reverse and sometimes in 1st gear. Is there anything I can adjust or is it time to replace it. It's not bad, but I notice it.
Old Jan 8, 2019 | 08:11 AM
v10climber's Avatar
v10climber
My suggestion would be the passenger side motor mount. They're not the most robust things out there and fail. To answer your other questions there is no adjustment for the clutch. The clutch can start to chatter if you have hot spots on the flywheel or pressure plate but if you're just street driving it normally I can't imagine that's your problem.
Old Jan 8, 2019 | 08:44 AM
I like mini clubman's's Avatar
If it's the original clutch then my guess is it's done. There is only a couple of mm of wear surface on these clutches. 100,000 is about it for normal driving.
Old Jan 8, 2019 | 10:35 AM
goody211's Avatar
goody211
Thanks v10, I'll make a visual and maybe stick a jack under it just to make sure it's still tight. Thanks again
Old Jan 9, 2019 | 04:44 AM
v10climber's Avatar
v10climber
FWIW when the mount failed on our old car and caused a shudder when starting to move there wasn't anything wrong with the mount visually. However, replacing the mount fixed it. Ours was an auto-x car and talking to other autocrossers with R56s they suggested the motor mount as they failed often with hard driving/launches.
dquarter87
Aug 14, 2014 11:44 PM
lowsid3r
Mar 11, 2013 07:32 AM
DreamMini
Oct 15, 2011 11:55 PM
T2Nav
MINI Camera and Video
Nov 5, 2007 05:31 PM
dave
12
Oct 25, 2004 08:40 PM
