R56 Cold engine shutter
Old Aug 14, 2014 | 08:18 AM
dquarter87's Avatar
dquarter87
Cold engine shutter
I've got an 09 MCS that has started a slight shutter when it's cold at idle. It will be normal then shutter then be normal again, it's intermittent. Doesn't feel like it wants to die, I don't have to Rev or anything, it's this the beginning of the tensioner letting go? If not what else should I look at? I've got the valve cover gasket and oil lines on my list to replace in the next week or so.
Old Aug 14, 2014 | 08:47 AM
Grizld700's Avatar
Grizld700
By cold do you mean outside? Or that the engine is cold (starting after it sat for a few hours)?
Old Aug 14, 2014 | 08:48 AM
dquarter87's Avatar
dquarter87
Cold engine
Old Aug 14, 2014 | 08:51 AM
Grizld700's Avatar
Grizld700
Could be several things. Your carbon build up could be rather excessive if you haven't had the valves blasted. You could also have carbon build up in the combustion chambers (this was my case). Poor fuel can cause this as well. High pressure fuel pump may be on its way out. Tensioner is not out of the question, but unlikely. Do you get any warning lights at all?
Old Aug 14, 2014 | 08:53 AM
dquarter87's Avatar
dquarter87
No warning lights, and once the engine warms up it goes away completely.
Old Aug 14, 2014 | 08:54 AM
dquarter87's Avatar
dquarter87
Haven't noticed a decline in fuel mileage or anything like that either
Old Aug 14, 2014 | 09:02 AM
dquarter87's Avatar
dquarter87
Might try some seafoam this weekend, didn't even think about carbon buildup.
Old Aug 14, 2014 | 09:03 AM
Grizld700's Avatar
Grizld700
Could also have a very small vacuum leak that goes away once warm due to heat expansion. Basically, there a lot of things that could cause this. Will be very difficult to tell without codes or guess and check.
Old Aug 14, 2014 | 09:05 AM
dquarter87's Avatar
dquarter87
Gotcha. Well I know I'm doing the valve cover gasket and oil turbo lines next weekend and I'll try the seafoam this weekend..... So maybe one of those will fix it lol
Grizld700's Avatar
Grizld700
Seafoam will be good for a fuel tank additive to get to the combustion chamber. It will do very little for the intake valves (it may help a little, but doesn't fix the issue, if thats the issue)
Old Aug 14, 2014 | 09:07 AM
dquarter87's Avatar
dquarter87
So use it as an additive instead of directly into the PCV? Everything I was reading was saying the opposite, or did I read wrong?
Old Aug 14, 2014 | 09:09 AM
Grizld700's Avatar
Grizld700
No, you didn't read wrong, but it has shown mostly ineffective for the overall issue at hand. It'll help a little, but will not get the large pieces off the valves, if any at all.
Old Aug 14, 2014 | 09:11 AM
dquarter87's Avatar
dquarter87
Okay that's what I thought. The walnut blast being the best way I assume?
Old Aug 14, 2014 | 09:13 AM
Grizld700's Avatar
Grizld700
Absolutely. No known better way. Plus, if your going to be working on it anyway, that'll be a good time, as long as you have the proper equipment. You can use chemicals if you dont have a media blaster, but it'll take a lot more time to do so. There is a good write up on the process somewhere in the forums.
Old Aug 14, 2014 | 09:23 AM
dquarter87's Avatar
dquarter87
Awesome, I'll see if I can find it after work tonight.
Old Aug 14, 2014 | 11:41 AM
Grizld700's Avatar
Grizld700
I found a thread with a similar problem. It doesn't have a resolution, but it was from 6 months ago, so perhaps the member fixed the issue and nver updated the thread. You may want to pm the OP on that thread and see if they fixed it.
https://www.northamericanmotoring.co...-problems.html
Old Aug 14, 2014 | 11:44 PM
dquarter87's Avatar
dquarter87
awesome, thanks!!!
W0TM8
Dec 19, 2019 07:50 AM
TREX
Nov 2, 2019 07:31 PM
damncajun
Aug 17, 2015 08:25 PM
minipopkart
Aug 13, 2015 05:22 AM
