Boost leak?
Old Jan 4, 2019 | 05:52 PM
pinntucky's Avatar
pinntucky
Boost leak?
Hey guys!
I was driving to work the other morning and got to a spot where there are 2 stoplights that are very difficult to catch both green. The 2nd light turned and then my light turned, it is an entrance ramp to a highway, so I hit it pretty hard trying to make it. In 2nd grear, at full boost, high revs, about to hit third, I get a boost cut. Engine light on, high emissions code, no boost, lots of oily smelling exhaust. I limped it back home and pulled the codes tonight. B2AAA, P0100, P0302, P1113B. What did I break? I thought I blew a boost hose or something but they all seem intact. I have spark plugs coming. The misfire code concerns me a little. Has anybody else had the same issue before? Could I have damaged the BOV or diverter or whatever it is called on these things? Thanks in advance!
Old Jan 5, 2019 | 04:25 AM
MiniToBe's Avatar
MiniToBe
Pull out the spark plug on cyl 2 and see how it looks. Also look through the hole to see oil.
Clear codes and see what returns.
Old Jan 5, 2019 | 09:06 AM
pinntucky's Avatar
pinntucky
Not looking good so far. #2 is full of oil, the plug was completely dry and clean. The other 3 plugs are carboned up, cylinders were dry. I'll post some pics when I figure out how. Running to town to get and adapter for my compression kit so I can run the numbers.
Old Jan 5, 2019 | 11:23 AM
pinntucky's Avatar
pinntucky
Adding pictures
Number 2 plug
Number two
Number two piston top
Number 3 plug
Number 3 piston top
Old Jan 5, 2019 | 11:44 AM
MiniToBe's Avatar
MiniToBe
Yeah, you next step is compression to make sure. If compression is good across the cyls, then that was gas in the cyl not oil. In that case, your coil might've given up. You could swap coils to see if the fault moves
Old Jan 5, 2019 | 12:11 PM
pinntucky's Avatar
pinntucky
Compression around 120 across the board.
Now I wait for new plugs and try again.
Old Jan 5, 2019 | 12:15 PM
pinntucky's Avatar
pinntucky
must have been gas. Two hours later and it's dry in there.
Old Jan 5, 2019 | 01:13 PM
MiniToBe's Avatar
MiniToBe
That's good news....i think it is the coil then. Swap and try.
Old Jan 5, 2019 | 05:14 PM
pinntucky's Avatar
pinntucky
Swapped the coils and cleaned the plugs. Codes all went away in the shed, but it is still running bad and smoking like a 2 cycle. New plugs come in the mail Monday, I'll get some used coils Monday too. See if it all goes away.
Old Jan 5, 2019 | 05:28 PM
AZdsrt's Avatar
AZdsrt
Those plugs need replacing in any event. The good news, compression is good. Just need to chase down the problem
Old Jan 7, 2019 | 05:21 PM
pinntucky's Avatar
pinntucky
New plugs and "new" 70,000 mile coils installed. Got a new code. Rich on bank 1 and she backfires a little. Do I need new O2 sensors too? Car has 109,000 and it was blowing oil for the last week.
Old Jan 7, 2019 | 10:20 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
N14 engine?
Assuming it is - there's the two most common N14 issues, 1) carbon build up, 2) PCV system gone bad causing oil high oil consumption and even more carbon build up.
Old Jan 8, 2019 | 06:14 AM
pinntucky's Avatar
pinntucky
This particular car had the head off at some point after a timing chain failure, all done by a Mini Dealer. I would assume they took care of the carbon buildup while it was apart. As for the PCV system, I'll look into cleaning that our or replacing it. For now, i think i'm just going to go run this this hard and see if i can burn out the cat. I think it is a little full due to the misfire and running rich for a miles.
Old Jan 8, 2019 | 07:18 PM
sawicki's Avatar
sawicki
Doubtful they cleaned the valves or the PCV when it was in for the timing chain.
Old Jan 8, 2019 | 08:29 PM
squawSkiBum
Moderator
If you're blowing oil out the exhaust, find and fix that first.
Old Jan 14, 2019 | 04:53 AM
pinntucky's Avatar
pinntucky
I found one potential leak point. On my intake manifold, there are vacuum points on each rubber. The plastic tee fittings are all brittle. Where can
I find replacement parts? The local discount Auto parts places don't carry fittings individually.
Old Jan 14, 2019 | 08:05 AM
sawicki's Avatar
sawicki
Local hardware store should have those types of fittings.
Old Jan 14, 2019 | 12:08 PM
pinntucky's Avatar
pinntucky
Are those vaccum ports stock on the 07? i don't see them on the Pelican Parts pictures or on any of the stock photos.
Old Jan 14, 2019 | 01:22 PM
squawSkiBum
Moderator
That's the cold weather version - should be able to look it up on realoem.com
This: https://www.northamericanmotoring.co...-manifold.html
Old Feb 6, 2019 | 06:24 AM
pinntucky's Avatar
pinntucky
Just an update... I stopped by my local Mini Dealer (3hrs away) and picked up the vacuum tee fitting for the cold weather intake. I then dove into the pressure side of the boost circuit. I found the diverter valve to have failed. A replacement is on the way, along with new intake manifold seals, a new valve cover seal and the vacuum pump rebuild seals while I'm in there. I will probably blast the valves too since it is all opened up. I'll report back if these all solve my issues. FWIW, the throttle body was super clean due to the cold weather intake. All that PCV oil mist goes directly onto the valves!
DRoc7822
Feb 15, 2016 12:47 PM
SooperCuperErik
Dec 16, 2011 11:58 AM
Marwan
Apr 23, 2011 08:29 AM
ortuna
May 23, 2010 10:33 PM
Mr. Incredible
Mar 20, 2009 11:22 AM
