P0108 MAP Sensor (I think)
Old Jan 3, 2019 | 11:26 AM
kmwoods's Avatar
kmwoods
I have a 2012 Mini, base version all stock. Threw an emissions icon. Also really rough start, which smooths out after a surge or two. Looked it up and the suggestions I see are MAP sensor. I have found ways to test the MAP sensor so want to try that. But I cannot find a good, actual, picture of the engine bay with the MAp sensor highlighted. Is it under the airbox maybe?
Thanks for any help!
Old Jan 4, 2019 | 06:49 AM
kmwoods's Avatar
kmwoods
Any idea at all? I see the diagram on the realoem site, and it looks like it shows it on the driver's side of the engine. But I can't tell from the diagram if I have to move something in order to see it.
Old Jan 8, 2019 | 06:12 AM
kmwoods's Avatar
kmwoods
Nothing?
Old Jan 8, 2019 | 07:51 AM
MrGrumpy's Avatar
MrGrumpy
Sorry nobody has replied yet. The MAP sensor is located on the top of the intake manifold, under the airbox. You will need to remove the airbox to see and access it.
you can’t miss it, it’s the only thing bolted to the top of the manifold with a plug and wire connected to it. Take out the single 8mm bolt, and it pops out. There is an o-ring on it, make sure it is intact and not missing or torn.
Edit: From a brief glance on the web, it looks like the MAP sensor is the same for the S and base models.
Old Jan 8, 2019 | 11:31 AM
kmwoods's Avatar
kmwoods
OK awesome. I don't know why I can't find a picture of this anywhere. Under the airbox is what I was thinking but don't have the car with me right now. Thank you so much for the answer. I really really appreciate it.
Old Jan 8, 2019 | 12:21 PM
MrGrumpy's Avatar
MrGrumpy
Here’s a picture of what it looks like and where it is on my S model.
Im pointing at it there on top of the blue boost tap. Yours will be there without the blue piece.
Old Jan 8, 2019 | 12:53 PM
kmwoods's Avatar
kmwoods
OK against the firewall under the airbox. I appreciate the help immensely.
Ken
Old Jan 8, 2019 | 01:03 PM
MrGrumpy's Avatar
MrGrumpy
No problem, it isn’t right against The firewall, but it’s close to it, whithin 6 inches or so.
Old Jan 8, 2019 | 06:00 PM
kmwoods's Avatar
kmwoods
Hmmm, I didn't find it. Is it under the air intake on the driver's side? Or is it on the passenger side. This car didn't look exactly the same.
Old Jan 9, 2019 | 06:42 AM
kmwoods's Avatar
kmwoods
I took some pictures of the engine compartment with the air intake removed. Not seeing the MAP sensor there. I did notice a rubber hose just hanging lose not connected to anything. Any idea what this hose goes to? I don't see anywhere to connect it.
Old Jan 9, 2019 | 10:10 AM
MrGrumpy's Avatar
MrGrumpy
Try a little wider shot so we can see the whole engine in there without the airbox. It should be right on the intake manifold. As far as the line that’s not hooked up, the bigger picture of the engine should help there too
Old Jan 9, 2019 | 10:23 AM
MrGrumpy's Avatar
MrGrumpy
Ok I took another look online and it looks like it’s not quite in the same spot after all.
its down on the the front right hand side of the intake manifold, if you are facing the engine from the front, try looking here. Also the loose hose could connect to the airbox.
Old Jan 9, 2019 | 10:35 AM
kmwoods's Avatar
kmwoods
OK I had seen an image similar to that one but wasn't sure it was looking from the front. I have looked all down in that area but will look again. You may be right about that line. I removed the airbox to find the MAP sensor and it may have come loose. When I checked the airbox I didn't see where that line connected. I'll double check it all. I do have a couple of other pictures I can check.
Man I really appreciate your time.
Jassim96496
Feb 25, 2015 11:54 AM
Carmichael
May 23, 2014 12:12 PM
SPRINTCARS
R60/61 Cooper S Drivetrain
Nov 13, 2013 07:50 PM
07PepperS
Apr 17, 2007 03:07 PM
kmickey
Mar 13, 2006 06:32 PM
