Fuel rail pressure sensor....Don't buy a rail!
Old Dec 28, 2018 | 05:07 PM
wesmc's Avatar
wesmc
After sitting my car had two issues. One was the top won't go down. I posted that earlier. Second was a "restricted performance" message. This turned out to be the fuel rail pressure sensor. Both BMW/Mini and the local independent shop said the sensor isn't available alone, I have to buy a rail. So I pulled the intake, removed the sensor, got the part # off it, ordered it from the BMW desk instead of the Mini desk and it was there the next day. Put a hundred miles on her now, no issues.
Old Dec 29, 2018 | 05:43 AM
I like mini clubman's's Avatar
Excellent information, thanks
Old Mar 6, 2020 | 11:43 PM
Choco's Avatar
Choco
Could you tell us what the part number was?
Old Mar 10, 2020 | 06:02 AM
seandallen's Avatar
seandallen
Do a google search for part #6PH2001.2 or 6PH20012. That will be the fuel rail pressure sensor. MINI doesn't list it as a separate part because the service recommendation is to replace the entire rail and to never replace just the sensor. But it it does just screw right out; it's just a little PITA to get to (it's right under the intake manifold, which needs to be removed).
Old Mar 10, 2020 | 06:31 AM
Choco's Avatar
Choco
Thanks, Sean. I found a few yesterday and probably should have followed up on my own reply when I did. But good to have confirmation.
They can be found at ECS, Pelican, FCP, and even Amazon if you trust the vendors there. Listed under both BMW and Mini.
I had more luck with part number 13537537319 but both will work. Listed below.
Part No.:
6PH2001.2
6PH20012
13537537319
13-53-7-537-319
13 53 7 537 319
Old Mar 18, 2020 | 09:16 AM
Yep we found that out a while back.
https://www.northamericanmotoring.co...ame-issue.html
Just check the part as their are 2 styles. We carry the one right now.
brmini
Apr 1, 2023 11:32 PM
Cruztpirate
Feb 10, 2020 06:58 AM
TAH1
Oct 22, 2019 08:06 PM
thanaldo
Nov 17, 2014 10:04 AM
phone
May 20, 2007 09:25 PM
