Turn Signal Replacing
Old Dec 28, 2018 | 07:00 AM
IDOXLR8's Avatar
IDOXLR8
Any one changed out a turn signal / headlight switch / dimmer in a 2003 MINI?
Old Dec 28, 2018 | 07:22 AM
cristo's Avatar
cristo
Alliance Member
Yes, about 5 or 10 years ago.
It was pretty easy to do.
Make sure you get the right part (with vs. without OBC).
Old Dec 28, 2018 | 07:28 AM
IDOXLR8's Avatar
IDOXLR8
Got the correct part from a excellent Vendor on our forum, just looking into how to change it. Looks like the steering wheel can stay on.
Old Dec 28, 2018 | 10:24 AM
cristo's Avatar
cristo
Alliance Member
If I remember correctly, the tach comes off with two small allen screws and pulling off the connector,
then the plastic shroud comes off after taking off two Phillips screws in the bottom one,
then the turn signal stalk comes out after removing one Phillips screw and pulling the connector off.
Then just put back together - no coding needed.
Old Dec 29, 2018 | 10:36 AM
IDOXLR8's Avatar
IDOXLR8
Thanks! If I can do a engine swap in this I think I can handle this! LOL!
Old Jan 12, 2019 | 10:56 AM
IDOXLR8's Avatar
IDOXLR8
Are there any U Tube videos on replacing a turn signal switch in a 2003 Mini?
Old Jan 12, 2019 | 11:17 AM
IDOXLR8's Avatar
IDOXLR8
2003 Turn Signal Switch Replacement
Why are there are NO U tube videos on 2003 Turn Signal Switch Replacement?
Old Jan 12, 2019 | 12:39 PM
cristo's Avatar
cristo
Alliance Member
Nope
But you can watch this one through
about 2:35.
At this point you just remove the screw
holding the stalk on, unclip the connector,
pull the old stalk out, put the new one in
and connect it, put the screw back in, then
reassemble everything.
Ignore the rest as you don’t have to take
the airbag cover off.
Old Jan 12, 2019 | 12:54 PM
AoxoMoxoA's Avatar
AoxoMoxoA
Why don't you make one when you do it, then there will be!
Old Jan 12, 2019 | 03:20 PM
IDOXLR8's Avatar
IDOXLR8
I like the way you think! I often gave guidance on the the Corvette Forum, being a mechanic for 40+ years you have a excellent post!
Old Jan 12, 2019 | 03:29 PM
IDOXLR8's Avatar
IDOXLR8
Originally Posted by cristo
Nope
about 2:35.
https://m.youtube.com/watch?v=0L6jbP0qOkU
Thanks for the quick follow up! I was not so sure about the tach and the column cover, AL.
Old Jan 12, 2019 | 07:10 PM
AoxoMoxoA's Avatar
AoxoMoxoA
The forum eagerly awaits your YouTube video!
Old Jul 17, 2024 | 03:49 PM
Teuchter's Avatar
Teuchter
Did IDOXLR8 ever make that video detailing how to replace the turn signal switch/stalk?
gob15
Oct 14, 2018 02:30 AM
putttn
May 20, 2008 03:32 AM
bealzabubba
Dec 22, 2005 09:26 AM
chrisneal
May 18, 2005 09:31 PM
Vincenzo
Oct 26, 2003 05:03 PM
