2011 S N18 Engine: Eccentric Shaft motor Issue
Old Dec 27, 2018 | 06:25 AM
Mikescarano's Avatar
Mikescarano
Hello, A little background: I bought this Mini with an over heated engine. It had a warped head, replaced that and put new ring, bearing, water pump, timing chain, etc in it. Have it running well except for the eccentric shaft. I have tried to get the computer to relearn the position of the shaft but it keeps rotating all the way counter-clock wise until the half engine light comes on and it goes into limp mode. It doesn't seem to reset when the key is put in either. I have replaced the eccentric motor with another used motor and have the same issue but this seems to be more software than hardware. Can anyone help? Thanks
Old Dec 27, 2018 | 07:20 AM
FamousFlea's Avatar
FamousFlea
Did you follow this?
https://www.newtis.info/tisv2/a/en/r...-gear/Db6g9sBW
Old Dec 27, 2018 | 07:27 AM
Mikescarano
Yes, i did it exactly the way they instructed. Except I don't know what they mean by "Check function of Digital Engine Electronics". Thanks Mike
jamadeus
Mar 10, 2019 06:50 PM
Ernie Orwig
Apr 19, 2018 04:56 PM
deschodt
Mar 31, 2016 12:37 PM
