Suspension R57 Suspension OEM Replace
Old Dec 26, 2018 | 10:18 AM
ZippMan112's Avatar
ZippMan112
Hello, I'm looking for advise and your experience with the R57 Suspension. Really all I want to do is smooth out the ride not looking to lower or lift it. The first thing to go will be the run flats they are like driving on wagon wheels. What advise or experience do you have with just updating the OEM to an after market suspension to help with smoothing out the ride. What brands would you recommend?
Old Jan 1, 2019 | 11:14 AM
mbwicz's Avatar
mbwicz
I'm using Bilstein B6 shocks now, and am pretty happy. If you are not lowering it, the koni FSD (now called special active) also have some good reviews. I've used Koni Yellow shocks in the past and it was a nice improvement in ride over factory as well.
You are right, changing to standard tires will be an improvement over runflats, 16" will be a better ride if you have 17" now.
Don't be afraid to reach out to one of the sponsors of this forum to get their opinion. waymotorworks.com, ecstuning.com, and outmotoring.com are some choices.
Have fun,
Mike
Old Jan 1, 2019 | 11:43 AM
Fly'n Brick's Avatar
Fly'n Brick
+1 on the FSD/Special Active (SA?) strurs. Also, consider replacing the RSB with a stiffer adjustable.
Morganinaboat
Dec 14, 2016 10:08 PM
DERMotorSports
Jan 20, 2016 03:03 PM
bratling
Suspension
15
Apr 6, 2015 07:28 PM
AustinS
Sep 28, 2012 10:33 AM
