Navigation & Audio Diagnostic Issues after Aftermarket Head Unit Replacement
I have a justa r56 and my radio died. I am thinking about replacing the headunit to an after market system as the dealer quoted by 2k.
I have read on various threads that replacing the stock headunit could lead to issues with diagnostics. Does anyone know this to be the case in reality instead of just conjecture? Has anyone been told that their car has cannot be serviced? I called two dealerships and they both said it wouldn't be an issues. The OBD will connect just fine. They said that the only thing is that the mini would be able to receive software updates which they don't recommend in a mini of my age anyways.
Thoughts?
Thoughts?
My F56 has after market amp and the car has error codes if you scan it. I have had it in for service since install without issues. Not sure what would happen if other issues popped up on my car and dealership blamed my amp.
No idiot lights at all. Only a OBD scan with MINI level diagnostics shows all the errors of not having a factory amp. A regular free OBD app on phone doesn't show the errors. Keep in mind that I'm talking about an F series, don't really know how the R generation will work, but I suspect the same results.
My understanding is exactly the same, you just won't be able to update software. I have a 2009 D R56 with radio removed and double din installed. Have connected using a iCarsoft BMM V2.0 and it reads and clears codes without issue.
Navigation & Audio Aftermarket double din nav/head unit causing cel issues
Hooligans
Apr 15, 2018 02:00 PM
mvaladez14
May 2, 2014 10:05 PM
Navigation & Audio Installing an Aftermarket Head Unit (+Aftermarket Amp) through the old H/K
Cudda_Kine
Nov 4, 2010 02:11 AM
Navigation & Audio Will an aftermarket head-unit void the warranty on my HK?
DuNcE223
Feb 22, 2003 11:08 AM
