R50/53 Supercharger Maintenance?
Old Dec 18, 2018 | 10:07 PM
alconk's Avatar
alconk
I decided since I was changing my pulley to a 16% one that would also be the perfect time to change the oil even though I only have 69K miles on it. Both front and rear chambers had the correct amount but the rear oil was a greenish color and smelled horrible while the front chamber had a reddish brown color and smelled of normal oil. Is that normal??
Also does the Mini's take a special coolant? I'm used to the green, purple and red colored coolant but mine was a brownish color.
Old Dec 19, 2018 | 04:01 AM
TX-Mini05's Avatar
TX-Mini05
Brownish coolant, could just be dirty. Maybe rust build up. Or it could be oil mixing with the coolant system, which is bad. I’d flush the system with new coolant and go from there.
Old Dec 19, 2018 | 07:12 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Usually when we do a service we find one end will have half as much oil as it should and it always is dirty and smells bad. If yours was full you are in good condition change it and go.
We have a kit to help anyone wanting to do it themselves
https://www.waymotorworks.com/superc...t-r52-r53.html
As for coolant just use the green stuff. We do in our shop and it's fine. The factory stuff is just too expensive and we know one of the coolant manufactures makes it for MINI they just make it blue.
Old Dec 20, 2018 | 11:51 AM
alconk's Avatar
alconk
Well it''s all done and even added the 16% WMW pulley. This car is a beast! With the Miltek exhaust and CAI this car runs strong. Stock pulley gauge was showing 12psi and now it's showing 18psi. Very happy here!
stt816
Sep 24, 2018 06:55 AM
poushag
How to
Nov 11, 2013 09:26 AM
elide
Apr 6, 2013 08:55 PM
RHcoopers
Jan 13, 2013 01:45 PM
Corey986
Apr 3, 2008 07:18 AM
